Axminster Professional AP254SB Table Saw
108516
Special Price £1,349.98 £1,124.98 was £1,499.98 £1,249.98 Save £150.00 £125.00
  5. Half Star
10 Reviews
In Stock - Ready to dispatch
  • Large capacity, super strong, built for daily use
  • 2.5kW 1ph quiet and powerful induction motor
  • Twin extension table configuration
Perfect for daily use in a busy workshop
The Axminster Professional AP254SB Table Saw is super strong with a large capacity; a workhorse that can handle daily use in a trade environment. Carefully designed and packed with useful features, its size makes it ideal for those limited on space.
Three year guarantee
Buy with confidence
Cast iron tables
Cast iron tables
The large fine ground cast iron tables provide smooth running, reduced vibration and a long life for your table saw.
Independently mounted table & trunnion assembly
The trunnion assembly is mounted independently on the saw's frame, relieving stress on the table and ensuring that the table remains flat and true over time.
Rip Fence
Solid "T" style dual height rip fence
Achieve close to the blade work as well as heavy duty ripping with the dual height rip fence, with a solid "T" style design for accuracy.
Extension Table
Set up the twin extension tables on either side of the saw for a traditional cabinet making style, or mount both tables on the right-hand side to handle large pieces.
Powerful 2.5kw motor
The quiet and powerful induction motor maintains blade speed for a consistent cut.
Twin mitre fence table slots
Twin T-slot mitre fence slots on both sides of the blade, ideal for jig use. Also supplied with a premium mitre gauge with useful pre-set angle stops.
Compatible with Dado Blade
With the available accessories of Dado Blade Table Insert and Overhead Crown Guard, the AP254SB is compatible with a Dado Blade Set which enables the easy cutting of grooves.
Dust Extraction
Dual dust extraction ports
Keep the saw line clear with a 63mm blade guard hose connection to clear above the blade as well as a 100mm rear outlet to clear below.
Heavy duty handwheels
Metal handwheels provide a smooth operation for blade adjustment.
Get the best out of your AP254SB
  1. Axminster Professional AP254SB Table Saw
Total:
£1,919.96 £1,599.97
The Axminster Professional AP254SB Saw Bench is built for daily use in a busy workshop. It has been carefully designed to include many useful features. It offers an impressive 80mm depth of cut and with the supplied twin extension tables, you can enjoy up to a generous 1,200mm width of cut to the fence. The motor, castings and trunnions are all mounted on the saw’s chassis. This is a much better and stronger option as it doesn't place any stress on the underside of the table.
The AP254SB’s chassis is heavy gauge steel, supporting the smooth cast iron table. A quality mitre fence runs in T-slot grooves provided on both sides of the blade. The full length fence is a rigid T-style which locks at the front, adjustment is smooth and easy. The rip fence comes with a Hi/Lo aluminium auxiliary fence.
The 2.5kW 1ph quiet and powerful induction motor gives you all the oomph required. Blade adjustment for height and tilt are controlled separately on individual handwheels.
A steel rear take-off is supplied, as well as an Axcaliber TCT general purpose blade. Two point dust extraction is via a 63mm connection on the blade guard hose combined with a 100mm outlet at the rear of the machine. Connection to a suitable extractor is recommended. The saw comes with two twin extension tables which can be set up on either side of the saw for a traditional style or both on the right-hand for a very general extension, and rear extension table.
Optional accessories include Sliding Crosscut Table, Overhead Crown Guard and Dado Blade Set for grooving.
N.B. This machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classifcation
These products are designed for frequent and extended use in professional environments, offering the performance and durability required for trade and workshop applications, without being intended for full scale professional or continuous use. They must be maintained and serviced annually. Guarantee is void when used for industrial use or part of a production line.
Learn more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.5 10
