Axminster Professional AP2770BS Belt Sander - 230V
107630
From £1,899.98 £1,583.32
  5. Half Star
2 Reviews
In Stock - Ready to dispatch
  • Sander belt runs at any angle between 0° and 90°
  • Precision ground steel plate belt platen with low friction graphite slip plate
  • Belt oscillation by heavy duty worm gear mechanism running in an oil bath
  1. Axminster Professional AP2770BS Belt Sander - 230V
Total:
£1,922.46 £1,602.05
The AP2770BS oscillating belt sander includes several well thought-out features. Suitable for any medium sized joinery workshop or cabinet maker's workshop, it is very well guarded and easy to use. It can be used horizontally or vertically; the belt oscillates 50 times per minute providing a scratch free finish. In the vertical mode the work table can be raised by means of a hand wheel and adjusted to minimise the gap to the sanding belt. A large quadrant scale gives an accurate indication of the belt to table inclination for bevel work. Incremental stops are included for most popular angles. An additional use is as a small vertical drum sander with the fitment of any of the three bobbins (38mm, 50mm and 75mm) supplied, using a small table assembly surrounding the idler roller. A robust, welded steel stand supports the whole machine and has a large cupboard for storing sanding sheets and accessories. Twin 100mm dust ports provide dust free operation when connected to a suitable fine dust extractor. A very well made and invaluable machine in any workshop.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
4.50 2
