Safety comes first with this powerful sander.
The AP305BDS has a 305mm diameter sanding disc fitted with a quadrant guard. The large cast iron work table features two mitre fence slots to 90° to each other, giving many options for sanding end grain or adjusting mitre joints. The table tilts to 45, with scales on the quadrant supports. Dust extraction is via a well-positioned 63mm diameter outlet.
The AP305BDS features a fail-safe electro-mechanical brake, which stops the disc rotating within 10 seconds. The brake does not require power, and works even in the event of a power failure in the workshop. This safety device is a requirement for organisations such as schools, colleges and training facilities.
The body is entirely fabricated from plate steel. Power comes from a 560W induction motor with a Euro style dust shrouded no-volt-release switch.
Supplied complete with a Hermes 305mm self-adhesive disc and mitre fence.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 63 mm
Overall L x W x H 671 mm x 445 mm x 410 mm
Power 560 W
Rating Frequent Use
Table Size 400 mm x 225 mm
Table Tilt 0 - 45
Min Extraction Airflow Required 390 m³/hr
Plug Fitted UK 3 pin plug
Model AP305BDS
Abrasive Disc Diameter 305 mm
Disc Speed 1,425 rpm
Nett Weight 32 kg
Voltage 230 V
EAN Barcode 5052511124916
