Axminster Professional AP305PS Panel Saw - 230V
107663
Special Price £5,999.98 £4,999.98 was £6,299.98 £5,249.98 Save £300.00 £250.00
1 Review
  • Enquire - contact us for a personalised quote
  • Power and accuracy with large cutting capacity
  • Super smooth sliding table takes 8 x 4 sheet with ease
  • Extendable cross cut fence with dual flip stops
  • Independently adjustable 120mm scoring blade
  • Rigid cast iron rip fence block
  • Large smooth precision ground cast iron table
  • Heavy duty steel material support frame
  • Separate motors for main blade & scoring blade
The Axminster AP305PS is packed with all necessary functions and features required from a panel saw in a professional modern workshop. The build quality combined with a large cutting capacity ensures the AP305S represents excellent value for money.
This is a well designed and engineered machine with a heavy gauge steel base and a generous cast iron table is built to last.The AP305PS is fitted with separate motors for the main and the scoring blade. Both blades are independently adjustable. Driven by a 2.25kW braked motor via a multi-V-belt ensuring quiet operation the 305mm main blade gives a maximum depth of cut of 90mm.
Cutting a 2,440 x 1,220mm (8' x 4') sheet isn’t a problem with the 2,600mm sliding table. The mechanism runs super smoothly, the well sized crosscut support table includes a long mitre fence complete with flip stops for accurate repeat cuts. The crosscut support table can be removed if required, saving space when not needed. Rear outfeed and right hand support tables are included, giving a sizable working area for sheet work.
Efficient dust control from the blade is via a direct dust outlet and ensures dust free operating when connected to a suitable extraction system.
The AP305PS combines accuracy with ease of use, a great asset to any busy workshop. An Axcaliber Premium 96 tooth low noise, fine crosscut blade is included.
N.B. This Machine requires a 32amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
5.00 1
