Axminster Professional AP310T2 310mm Thicknesser - 230V
A 0% interest offer you can use again and again.
PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Perfect for uniform board production or frame making
- 4 row Spiral cutter block with 52 TCT indexing cutters
- Large table with support rollers, fitted with digital height gauge
Axminster Professional Universal Mobile BaseSpecial Price £132.58 £110.48 was £155.98 £129.98 Save £23.40 £19.50
When it comes to producing timber to a uniform thickness, with parallel faces and edges, a thicknesser is unbeatable.
The AP310T2 has power and strength in abundance with a cast iron frame and table, supported on a sturdy steel base. Power comes from a 2.2kW induction motor. The long 930mm long table has additional support rollers at each end. A digital height gauge aids accurate setting.
By far, the machine’s best feature is the spiral cutter block. Four rows of TC cutters, give an almost perfect finish. The cutters are arranged to produce a super clean shear cut. With each cutter having four edges you can simply turn to a fresh edge when required. If one or more cutters are damaged, then simply replace it. Each edge lasts up to 10 times longer than that of an HSS blade, greatly reducing downtime. There is no setting, saving more time and guaranteeing accuracy. The combination of the angled cutter and curved edge is much kinder on the timber, even heavily figured timber presents no issues with tear-out. The other main benefits of this type of cutter block: much lower noise, and much reduced power required to drive it. The waste chips are much more uniform, being easier to extract and packing more into your extractor's waste container.
This solidly built, relatively compact machine is capable of handling quite large board runs or sizing frames or beams.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Axminster Professional 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
Cuts per Minute | 16,000 |
Cutterblock Diameter | 95 mm |
Cutterblock Speed | 4,050 rpm |
Dust Extraction Outlet | 125 mm |
EAN Barcode | 5052511124480 |
Feed Speed | 6 m/min |
Knives | TC Spur Cutters x 52 |
Length of Table | 930 mm |
Max Depth of Cut Thicknesser | 3.0 mm |
Max Thicknessing Height | 220 mm |
Max Thicknessing Width | 310 mm |
Min Extraction Airflow Required | 1,300 m³/hr |
Min Thicknessing Height | 5.0 mm |
Model | AP310T2 |
Nett Weight | 200 kg |
Overall L x W x H | 1,050 mm x 610 mm x 1,020 mm |
Plug Fitted | UK 16A Plug |
Power | 2.2 kW |
Rating | Trade/Professional |
Sound Pressure Level LpA [Uncertainty K] | 84 dB(A) [2.0 dB] |
Voltage | 230 V |
- UK Mainland - £70
- UK Remote & Offshore* - charge advised in basket
