PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
The AP3327B bandsaw is the perfect choice for any trade or large home workshop.
Fine Finished Cast Iron Table
The smooth finish of the table makes it easier for the workpiece to move across the table.
Solid Rigid Welded Steel Chassis
The construction of the chassis helps to keep any vibration to minimum.
Quick Release Blade Tension
This feature helps to reduce downtime when changing blades and also reduces wear on tyres.
Two Speeds
The high speed is ideal for making thinner cuts, while the low speed is best for making thicker, heavier cuts.
Guide Height Control
For quick, simple and accurate set up, the guide height is both rack and pinion controlled and features ball bearing guides.
Table Tilt Control
Rack and pinion table tilt control makes for quick and easy adjustment.
Dual Position Rip Fence
When the flat wider side is facing the table it is ideal for thinner material. In addition it also allows you to keep your fingers out of the way. Alternatively, when used with the smaller side towards the table, it is ideal for cutting thicker material and gives maximum support for veneer cutting.
Twin dust ports
The bandsaw features two ports for efficient dust extraction. This also helps to safeguard your health.
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
A bandsaw is probably the most versatile machine in any workshop and often the first machine used when preparing timber. With a powerful motor, large capacities and made to the exacting standards we expect of our Professional range of machines, this bandsaw has become firmly established. It offers excellent safety features including braked motor and interlocked doors and twin extraction ports.
A rigid welded steel chassis, cast iron table and heavy duty bearing blade guides are standard, along with a rigid rip fence and precision mitre fence. One often overlooked feature is the ease of changing the blade; it has a quick release blade tensioning lever which substantially speeds up the process of blade changing. Two belt speeds offer the right speed for the job, big or small. A wide range of blades is available, all made in Axminster. First class build quality, ease of use and versatility mark this bandsaw out as a top machine for professional use. Supplied with rip fence, mitre fence and 13mm x 6tpi bandsaw blade.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Max depth of cut 300mm, max width of cut 410mm
Braked induction motor and electrically interlocked doors for safety
Rigid rip fence with magnified scale lens and accurate mitre fence
Machine Classification
This product is classified as a Large Delivery
product and will normally be delivered within 14 working days.
This is a Bespoke Large Delivery service. Our team will contact
you upon completion of your order to discuss carrier options and arrange a
delivery date to suit you.
UK Mainland - £60
UK Remote & Offshore* - charge advised in basket
