PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
The AP340PD packs all the features of its larger cousins into a slightly more compact size. This professional pillar drill is strong, reliable and accurate. Built mainly using cast iron and precision machined for consistent performance. The quill is 2MT and fitted with a quality 1mm to 16mm keyless chuck. Powered by a smooth running 550W induction motor, it has 12 belt speeds between 210 and 2,580rpm. The belts are of the multi-vee type, for maximum grip and the lowest level of vibration. The belt cover has a safety switch to prevent the drill being run with the cover open. The down feed is via a one-piece cast iron handle with soft rubber grips. There is an accurate drilling depth control. The chuck guard is electrically interlocked for safety and is easily adjustable for height. The on/off switch has a separate locking emergency stop switch, plus a switch for the integrated LED work light. Table height is controlled via a rack and pinion; the whole table assembly can be swivelled away to allow the base to be used as a work support. A great choice for any professional or educational workshop.
Please note, morticing attachments are not suitable for this machine.
Cast iron construction for strength and stability
2MT quill fitted with quality keyless chuck, 1-16mm capacity
Convenient rack and pinion table height adjustment
Machine Classification
