Step up your turning game...
The Axminster Professional AP460WL Woodturning Lathe is a medium sized machine that brings together power, control, and versatility in a well-balanced design. As the first floor standing lathe in the latest Axminster Professional range, it's engineered for enhanced stability and performance, delivering a solid, dependable feel across a wide range of turning tasks. It makes the perfect step up from a bench lathe and is ideally suited to medium to large scale projects.
Buy with confidence
Heavy cast iron construction
The cast iron construction ensures stability and with 187kg of mass, vibration is reduced for smooth, controlled results, even when working with large or unbalanced timber.
M33 x 3.5mm ASR safety spindle
The M33 x 3.5mm ASR safety spindle allows the work to be held safely if using the lathe in reverse.
Inboard and outboard turning
The headstock both slides and rotates, offering multiple locking positions that provide better access and flexibility when turning bowls.
Swing away tailstock
The swing away tailstock further enhances accessibility, making hollowing and outboard turning easier and more efficient.
Powerful motor
A high torque 1.5kW motor delivers consistent torque and power for larger, demanding projects.
Electronic variable speed
Benefit from two variable speed ranges: 0-1,350 RPM and 0-3,500 RPM, for smooth, precise control. Dual belt ratios optimise torque, making it easier to handle larger or heavier workpieces with confidence. The digital speed readout makes it easy to stay in control.
Magnetic switch box
The magnetic switch box allows you to position the switches in the most convenient position for you for more control.
Cam-lock banjo and tailstock
The banjo and tailstock uses a cam-lock for quick, effortless setup to minimise downtime.
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Axminster Professional AP460WL Woodturning Lathe is a medium-sized, floor standing machine designed to handle a wide range of turning projects with ease. Versatile, solid, and intuitive, it offers the control and reliability needed for both developing and experienced turners.
Its heavy cast iron construction provides 187 kg of mass, ensuring excellent stability and minimising vibration for smooth, controlled results, even when working with large or unbalanced timber.
With 610 mm between centres and a 460 mm swing over the bed, the AP460WL woodturning lathe is well suited to both spindle work and bowl turning. It comes supplied with a 410 mm bed extension and a 220 mm tool rest extension, increasing its capacity for larger projects such as platters and bowls.
The headstock swivels through 180° and features multiple locking positions for improved access during bowl turning. A sliding headstock allows outboard turning at the end of the bed, making it easier to work on larger pieces. The tailstock can also be swung away, providing better access for hollowing or outboard work. In addition, 24-position indexing supports decorative and segmented turning.
A powerful 1.5 kW motor delivers consistent torque across the speed range, including at low speeds, ensuring smooth performance in all conditions. Electronic inverter-controlled variable speed, combined with dual belt ratios, allows precise adjustment for both delicate work and larger, out-of-balance pieces, with speed ranges of 0-1,350 rpm and 0-3,500 rpm.
For added convenience, the magnetic control unit can be positioned anywhere on the lathe bed or headstock. It features clearly arranged on/off buttons, a speed control dial, and a forward/reverse switch, allowing easy operation from wherever you are working.
Integrated tailstock storage keeps essential tools close at hand, helping maintain an efficient and organised workspace.
The lathe features an M33 x 3.5 mm ASR spindle, compatible with all standard M33 x 3.5 mm threaded chucks and accessories. The ASR system includes a safety groove, designed for use with compatible fittings and a locking ring to ensure secure operation in reverse. This feature is optional for general turning.
The AP460WL Woodturning Lathe provides excellent capacity, performance and turning capability. It's a robust lathe that can grow with your skills and handle demanding projects with ease.
Supplied with 100mm, 200mm and 300mm tool rests, 220mm tool rest extension, 150mm faceplate, 4-prong drive centre, live tailstock centre, swing away tailstock and a 410mm bed extension.
Please note, if you require an EU plug, please ensure you purchase 113776
Overall L x W x H 1,528 x 500 x 1,240 mm
Power 1.5 kW
Rating Frequent Use
Model AP460WL
Distance Between Centres 610 mm
Headstock Taper 2 MT
Lathe Speed 0 - 1,350 / 0 - 3,500 rpm
Max Diameter over Bed 460 mm
Nett Weight 187 kg
Spindle Thread M33 x 3.5 mm (ASR)
Tailstock Ram Travel 115 mm
Tailstock Taper 2 MT
Tool Post Diameter 25.4 mm (1)
Voltage 230 V
EAN Barcode 5052511142224
  • UK Mainland - £70
