PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Weighing an impressive 280kg it’s strong stature provides a huge amount of strength, whilst also dampening down vibration. Smooth movement of the headstock, banjo and tailstock is enabled with the brush finish on the bed surface.
Made almost entirely in cast iron, with the bed being particularly wide and well braced. Cast iron stand legs are included, providing a stable platform for the lathe.
Electronic Variable Speed Control Unit
The variable speed control unit enables you to adjust the speed to suit your project; delicate work, larger diameters or out of balance work pieces.
A magnetic back also allows the unit to be placed in any convenient position on the lathe bed or headstock to suit the work in hand.
2.2kW (3HP) Motor & Variable Frequency Inverter Drive (VFD)
Fitted with a quality variable frequency inverter drive (VFD) this ensures a super smooth start, acceleration and deceleration which is all powered by a 2.2kW (3HP) motor.
Distance Between Centres
This lathe includes a bed extension which makes the distance between centres a massive 1,262mm or 762mm without the bed extension. Unusually, this lathe can be used with the bed extension fitted on either end of the main bed. To increase the bowl diameter the bed extension can be bolted onto the lower position on the leg casting, or fixed at right angles on the main bed located on the machined mounting plate to allow easy access for bowl turning.
Supplied with high quality centres
The lathe is supplied with high quality stainless steel Four Prong Drive and Revolving Tailstock Centres; both designed and manufactured in Axminster, UK.
Headstock
The headstock can be slid along the full length of the bed and swivelled through 360° with indexing stops every 45°. This allows the headstock to be moved in a number of positions to gain better access to the workpiece.
Banjo
Made from cast iron construction with an easy to use, cam lock lever. A 30mm stem provides strength and support for the tool and helps reduce vibration. The tool rest holder has a wide base with an offset stem socket for increased rigidity. Two tool rests are provided, 150 and 300mm.
Tailstock
The tailstock has an exceptionally long quill travel of 135mm. It is etched with a scale and is unusually fitted with a digital readout, useful for precision hole boring. A long cam clamp lever locks the tailstock firmly in place and is easy to adjust.
3 Year Guarantee
For complete peace of mind, we cover all parts and labour free of charge for three years.
This is the largest in our Professional Series woodturning lathes. It has all the features a serious woodturner would need for almost any woodturning project, large or small. Made almost entirely in cast iron, with the bed being particularly wide and well braced. Cast iron stand legs are included, providing a stable platform for the lathe. Vibration is virtually undetectable due to the mass of cast iron employed in the construction.
The extension bed that comes with the lathe, can be mounted in any one of three positions. Either, on the end of the main bed to extend the distance between centres, on the leg of the stand to allow large diameter work, or on a mounting plate machined onto the side of the bed. This allows bowl turning with the headstock rotated to suit. The headstock can be slid along the length of the bed and rotated through 360° with indexing stops every 45°.
The headstock spindle is driven through a 10-groove multi V belt with a choice of three ratios; this coupled with the variable speed function gives a very wide speed range of 60 to 3,700 rpm. A remote control box with a magnetic back can be placed wherever you want and allows easy control. A forward and reverse direction switch is also fitted. The spindle has 24 indexing positions, held by a threaded stop pin. A separate spindle locking pin is provided, with a handy magnetic base.
The tailstock has an exceptionally long ram travel of 135mm, is etched with a scale and is unusually fitted with a digital readout, useful for precision hole boring. A long cam clamp lever locks the tailstock firmly in place and is easy to adjust. The tool rest holder has a wide base with an offset stem socket for increased rigidity. Two tool rests are provided, 150 and 300mm.
This is a top quality, fully featured lathe for the serious woodturner. With this machine in your workshop there would be very few woodturning projects you could not undertake.
Supplied with Axminster Woodturning drive and tailstock centres.
Heavy duty all cast iron construction for massive stability
2.2kW motor with variable speed and 3 speed ranges
Supplied with bed extension for large diameter bowls or long spindles
Headstock slides and rotates on the bed for ease of use
Tailstock ram has digital position readout for precision working
Machine Classification
This product is classified as a Large Delivery
product and will normally be delivered within 3-5 working days.
This is a Palletised Large Delivery service.
A specialised palletised goods carrier that will deliver to kerbside only.
The carrier will be in contact to confirm the delivery date.
UK Mainland - £60
UK Remote & Offshore* - charge advised in basket
Please enable "Performance Cookies" for our best Reviews and Q&A experience. To change your cookie preferences please see our Cookie Policy.
Is there a heat cut out on the motor and how long can the motor run before overheating?
Asked by: Mustang Reg
I am not sure if a cutout exists however, I have run my lathe all day in my workshop turning bowls between 8 and 12 inch plus used a bowl saver and have never had the motor get hot. I guess it may get hot if you overload it by running it in the wrong belt position whilst using the bowl saver or taking very deep cuts. It’s a great large and very capable.
Answered by: StephenB
Date published: 2022-05-29
Hello, does this lathe require a 16amp supply ?
Asked by: Fodderty W
No l am plugged into a standard 13 amp socket
If you are thinking off buying this lathe I am more than satisfied you can’t go far rong
Answered by: Wyattearp
Hi,
Thinking of getting an extra extension bed along with this lathe. Can the headstock be held on the extension bed if there is another holding the tailstock? Considering this lathe for larger spindle work as well as bowls.
Thanks.
Asked by: Andy
Hello,
I can confirm that the headstock can be held on the extension bed if there is another holding the tailstock.
Sam
Specialist Sales Advisor
Answered by: Axminster Staff
Dose the AT508WL Woodturning Lathe have a set of wheels with it
Asked by: JJG
Hello,
Please note that we do not have any lathes or lathe stands with wheels.
Thank you
Grace
Specialist sales advisor
Date published: 2020-03-03
Can I buy the whole headstock on it's own.
Asked by: For what reason?
Hello
I would recommend you contact our After Sales team on 03332 406 406, option 2 option 2, they will be able to advise further on the price and availability of this.
Scott
Date published: 2022-09-27
Is this lathe available with a 3 phase power supply option?
Asked by: Gautham
Hello
This lathe is only available in single phase we are unable to supply this in a 3 phase version.
Kind regards,
Tony Harris
What is he actual length of the lathe bed please.
Asked by: Petjack
Hello
I can confirm that the lathe bed itself is 1400mm long.
Scott
