PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
The AP540PD is a solidly built floor standing pillar drill and a real work horse. It runs quiet and once fully bolted down to the workshop floor (a must for safety reasons) it is virtually vibration free. Cast iron and precision machined steel give this drill strength, stability, accuracy, and reliability.
It has a 1,100W induction motor, which runs fine connected to a 13A socket. There are 12 belt speeds; from 150 to 2,700rpm. Multi-vee type belts give maximum grip and reduce vibration from power transmission.
It has 3MT spindle taper and a highly accurate chuck spindle assembly, running in quality NSK bearings. A quality 3-16mm keyless chuck comes as standard. Down feed is via a one-piece cast iron handle with soft rubber grips; there is an accurate depth control.
Table height is controlled using a rack and pinion. The table tilts and can be swivelled away to allow the base to be used as a work support.
The switch system has a separate locking emergency stop switch, plus there is a separate switch for the integrated LED work light. The chuck guard and belt cover are electrically interlocked for safety.
The AP540PD arrives 95% assembled, so no heavy lifting required.
Smooth running 1,1kW motor, 12 belt speeds 150-2,700rpm
Large table with rack and pinion height adjustment
3MT spindle, 3-16mm keyless chuck and LED work lamp
Machine Classification
This product is classified as a Large Delivery
product and will normally be delivered within 3-5 working days.
This is a Palletised Large Delivery service.
A specialised palletised goods carrier that will deliver to kerbside only.
The carrier will be in contact to confirm the delivery date.
UK Mainland - £60
UK Remote & Offshore* - charge advised in basket
