Axminster Professional AP640DS Drum Sander 230V
113351
From £2,399.98 £1,999.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Dispatching Soon
- Email me when available
Delivery
£70 Large Delivery*.
Dispatch estimate is within 4 weeks.
  • Heavy duty dual drum sander for fast, accurate finishing
  • 80g and 120g dual drums for rough and fine sanding
  • Powerful 3kW motor for consistent performance
  • Digital height adjustment for precise results
  • Rigid cabinet stand for stability
  • Balanced sanding rollers reduce vibration
  • Variable feed speed for ultimate control
  • Twin 100mm dust ports for efficient dust extraction
Dual drums, double efficiency
The Axminster AP640DS Drum Sander is a professional dual drum sander that combines speed, precision, and a smooth finish. With dual belts, digital height control, variable feed speed, efficient dust extraction and more, it delivers consistent, high-quality results while taking workshop efficiency to the next level.
Three year guarantee
Buy with confidence
Dual drum system
Dual drum system
Run coarse and fine grits simultaneously, in a single pass to reduce sanding time and deliver quality results.
Use the digital height adjustment scale to ensure exact worktable positioning every time, removing guesswork and improving repeatability. The large adjustment handle makes fine height changes quick and accurate.
Variable conveyor speed
The variable conveyor speed (0-4.6m/min) allows you full control over material feed rate, so you can achieve excellent sanding performance every time.
Heavy-duty cabinet stand
The heavy-duty cabinet stand ensures excellent stability and long-term durability, so you can get the most from your sander.
Balanced sanding drums
Dynamically balanced sanding drums minimise vibration for smooth, consistent operation and result in quality finished timber.
Dust extraction
Dust extraction
Two 100mm dust outlets provide efficient extraction when connected to a suitable extractor. The outlets remove dust with ease, leaving your workspace clear.
Get the best out of your AP640DS
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
The Axminster Professional AP640DS Drum Sander is a heavy duty dual drum sanding machine designed for workshops that demand speed, accuracy, and a flawless finish. With its dual-drum system, robust cabinet stand, 3kW motor and precise digital controls, the AP640DS Drum Sander delivers exceptional results across a wide range of materials including wood, plastics, and similar materials.
The advanced dual drum sanding system allows you to run 80 grit and 120 grit belts simultaneously, combining coarse material removal and fine finishing in a single pass. This dramatically reduces sanding time while delivering consistent, professional-quality results, especially with the power of the 3kW motor.
A digital height adjustment scale ensures exact worktable positioning every time, removing guesswork and improving repeatability. The large, ergonomically designed adjustment handle makes fine height changes quick, smooth, and accurate, even when working with demanding materials.
The AP640DS Drum Sander is built on a solid, heavy duty cabinet stand, providing excellent stability and long-term durability in professional environments. Dynamically balanced sanding rollers minimise vibration, resulting in smoother operation, reduced machine wear, and a superior surface finish.
The variable conveyor speed (0–4.6 m/min) allows full control over material feed rate, ensuring optimal sanding performance for both aggressive stock removal and fine finishing. Two 100mm dust extraction outlets efficiently remove dust and debris, keeping the workspace cleaner and improving air quality.
N.B. Drum sanders are used as part of the finishing process, they are not intended to be used as a planer/thicknesser or for significant stock removal. A drum sander does not replace a planer/thicknesser and vice versa. Drum sanders are intended to be used with already planed and thicknessed material. Overall a planer/thicknesser is meant to dimension timber, the drum sander to finish it.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Please note, if you require an EU plug, please ensure you purchase 113776
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed for frequent and extended use in professional environments, offering the performance and durability required for trade and workshop applications, without being intended for full scale professional or continuous use. They must be maintained and serviced annually. Guarantee is void when used for industrial use or part of a production line.
Learn more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
