Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
This is a medium sized, floor standing pillar drill. Cast iron and machined steel giving high strength, reliability and stability. It has a highly accurate chuck spindle assembly, running in NSK ball race bearings. Powered by a smooth running 750W induction motor, there are 12 belt speeds from 120 to 2,580rpm. The belts are of the multi-vee type for maximum grip and low vibration. The belt cover has a safety switch to prevent the drill being run with the cover open. The down feed is via a one-piece cast iron handle with soft rubber grips and there is an accurate drilling depth control. A quality 1-16mm keyless chuck comes as standard. The chuck guard is electrically interlocked for safety. The switch system has a separate locking emergency stop switch, plus a separate switch for the LED work light. Table height is controlled via a rack and pinion system; the whole table assembly can be swivelled away to allow the base to be used as a work support. A great choice for any trade or school workshop looking for a great performing floor standing pillar drill. Please note, this machine must be bolted to the floor for safe working.
Please note, morticing attachments are not suitable for this machine.
Machine Classification
This product is classified as a Large Delivery
product and will normally be delivered within 3-5 working days.
This is a Two-Person Large Delivery service. A two-person carrier
dedicated to delivering larger and heavier consumer goods into your room of choice;
whether in the home (including garden and garage) or at a business address.
The carrier will inform you of your delivery options.
UK Mainland - £60
UK Remote & Offshore* - charge advised in basket
