Axminster Professional Magnetic Saw Table Cover
- Protect machine tables
- Prevent against rust and corrosion
- Secure magnetic adhesion
- Rolls up for storage
Axminster Professional LED Stayput Strip LightSpecial Price £85.42 £71.18 was £113.88 £94.90 Save £28.46 £23.72
The magnetic saw table cover is designed to protect your valuable cast-iron and steel machine tables from damage and corrosion. Made from thick plastic, these covers adhere magnetically to create a tight seal that prevents rust, keeps out humidity, and protects against spills. The magnetic adhesion ensures that the cover stays in place and does not slide, providing reliable protection for your machinery.
In addition to safeguarding your tables, the magnetic saw table cover offers practical benefits for your workspace. You can use your table saw or router table as an assembly table, as glue from your projects will peel right off the cover. The thick magnetic sheet also helps protect your tables from scratches and impacts, while keeping hardware from rolling away.
When not in use, the cover can be easily rolled up for storage. Measuring 61 x 81 cm and 0.9 mm thick, this cover is a versatile and essential accessory for any workshop which provides great value for money.
EAN Barcode | 5052511136414 |
- Standard Delivery* - £1.99
