Axminster Professional Radius Edge CBN Wheel - 200 x 32mm - 180G
108039
From £139.98 £116.65
In Stock
- get it Saturday 3rd Jun, order within and choose Premium delivery. Delivery info
  • Sides feature 6mm radius for small or shaped tools
  • CBN cuts fast and cool, for a superbly sharp edge
  • Lasts many years, always flat, true and smooth running
Customers Also Bought
Total:
£369.42 £307.85
This CBN wheel is 200mm diameter and 32mm wide. The coating continues around a 6mm radius on each side. This is most useful for sharpening smaller or shaped tools, as it gives you more control over where metal is being removed. The wheel’s 180 grit coating produces sharp edges on HSS tools. Cubic Boron Nitride (CBN) is a ceramic abrasive second only to diamond in hardness for outstanding performance.
The wheels run ultra smoothly when fitted to a suitable bench grinder. CBN wheels are at their best when grinding HSS steels and hardened carbon steels. They are invaluable for maintaining the edges of woodturning tools and other hand tools. CBN is the best material for grinding hardened steels. Attempting to grind unhardened steel or soft metal such as aluminium or copper etc is detrimental to performance and results in a clogged wheel.
These wheels do not require coolant, as they generate hardly any heat. Very little pressure is required to sharpen a tool; generally, the weight of the tool alone is sufficient. The face of the wheel will never need dressing; it will always remain flat and run true.
These outstanding wheels have an almost indefinite life if treated with respect. Since they cut very efficiently, you only remove a minimum of steel to get a fine and evenly sharp cutting edge, meaning your tools last longer.
Please note, these wheels have a 31.75mm bore, adaptors may be required for fitting to some bench grinders.
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    5.00 2
