The Axminster Professional SD3886B bandsaw combines heavy-duty construction with precision engineering to deliver power, accuracy, and reliability for demanding workshops.
Featuring a 546 x 400mm cast iron table, this bandsaw provides an impressive 300mm depth of cut and 447mm throat capacity, making it ideal for heavy duty projects. The balanced 450mm cast iron blade wheels and solid cast iron table minimise vibration for smoother, more consistent results when working with materials of all sizes.
Switching from heavy rip cuts to fine, detailed work is effortless thanks to the Hi-Low rip fence, which offers excellent flexibility and control. Quick-release blade tensioning ensures fast, simple setup and adjustment.
Powered by a robust 1.5kW motor, the SD3886B bandsaw handles demanding cuts with ease. The rack and pinion table tilt mechanism allows for precise and rapid angle adjustments, further enhancing versatility.
For safety and cleanliness, micro-switched doors automatically stop the blade within 10 seconds of opening, while twin 100mm dust extraction ports help maintain a clear, dust-free workspace.
Supplied with a mitre gauge, this versatile bandsaw is ready for a wide range of woodworking applications.
Please note, if you require an EU plug, please ensure you purchase 113776
Dust Extraction Outlet 2 x 100 mm
Max Width of Cut with Fence 393 mm
Overall L x W x H 958 x 665 x 1910 mm
Power 1.5 kW
Rating Frequent Use
T Slot Size 19 mm
Table Height 960 mm
Table Size 546 x 400 mm
Table Tilt -50
Min Extraction Airflow Required 1,200 m³/hr
Sound Power Level LwA [Uncertainty K] 90 dB(A)
Sound Pressure Level LpA [Uncertainty K] 100 dB(A)
Plug Fitted UK 16A Plug
Model SD3886B
Bandsaw Blade Length 3,886 mm (153")
Bandsaw Wheel Diameter 450 mm
Blade Speed 400 & 900 m/min
Blade Width Min\Max 6 mm to 33 mm
Max Cutting Height 330 mm
Max Width of Cut 447 mm
Nett Weight 161 kg
Voltage 230 V
EAN Barcode 5052511142552
This product is classified as a Large Delivery product and will normally be delivered within 14 working days.
This is a Bespoke Large Delivery service. Our team will contact you upon completion of your order to discuss carrier options and arrange a delivery date to suit you.
  • UK Mainland - £70
