This sliding table for the Axminster Professional AP254SB saw bench, fits on the left hand side of the machine. It offers 930mm length of travel giving a maximum cross cut of 610mm and has a decent size 533 x 406mm table. The mitre fence features an easy to read degree scale for angular cuts up to 60. A long (1,160mm) work support rail includes an adjustable repeat stop and cam-lock hold down clamp.
Simple to fit and easy to adjust for spot-on alignment. This sliding table is solid and runs smoothly. The table casting is accurately ground. Crosscutting is a pleasure with this addition to your AP254SB, it glides smoothly along the rail for perfectly clean results every time.
Web Attribute Set Saw Bench Accessories
EAN Barcode 5052511127542
