Artisan Click Pencil Kits
- 10kt or 24kt
- Click mechanism uses plunger to advance lead
- Epoxy coating on 24kt version for added protection
- 'A' logo on the clip of the 10kt version
- Takes 0.5mm lead
The 10kt Click Pencil is of high quality and has a click type mechanism which uses a plunger on the top which, when pushed, extends the tip and advances the lead. There is an 'A' logo on the clip of the 10kt version. The 24kt alternative uses the same style of mechanism and is gold plated with an epoxy coating which gives some additional protection. This Kit is not quite as classy as the 10kt Artisan model but offers excellent value. Both pencils take a lead of 0.5mm. Requires 7mm drill. These pens can be turned using the bushes supplied as standard bushes with the Axminster Pen Mandrels.
Bushing Set Order No. | 8.5mm O/D (as supplied with mandrel) (100793) |
Difficulty | Intermediate |
Drill Bit Required | 7 mm |
Minimum Blank Size | 16 mm x 16 mm x 112 mm |
Pen Type | Pencil |
Refill Order Number | 502563 |
