Rider Double-Sided Diamond Bench Stone
- Sharpen plane irons, chisels and ceramic knives
- Double-sided premium quality stone with rubber non-slip surround
- Fine 1,000 grit (15 micron) and coarse 400grit (36 micron)
These 200 x 65mm double sided premium quality diamond stones give two options, just by flipping them over. We tested these extensively, medium 400G (36 micron) on one side and fine 1,000G (15 micron) on the other. Nickel plating permanently fixes the diamond particles onto the 8mm thick steel base. A chequered pattern carries away metal particles so maintaining the stone's cutting efficiency. On first use the diamond surface may seem aggressive, this is the same with all diamond sharpening stones. This is called the break-in period and will have no impact to long term performance. After a few sharpenings the stone will smooth. The resulting surface is more than capable of sharpening modern hard steels, ceramic knives as well as traditional tool steels. A protective non-slip rubber surround keeps the stone in place when in use. You can use it dry but it works far better with a splash of water.
| EAN Barcode | 5052511000722 |
| Grit | 400 / 1,000 |
| Overall L x W x H | 200 mm x 65 mm x 8 mm |
- Standard Delivery* - £5
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
