Rider Mortice Chisel
From £20.68 £17.23
  5. Half Star
44 Reviews
  • Tapered cross section prevents chisel binding in deep mortices
  • Fine-grained, chrome manganese steel blade gives ultra keen edge
  • Hardened and tempered to 59 HRC stays sharp longer
A good mortice chisel needs to be robust to withstand repeated heavy use when chopping out mortices or cutting other joints. The Rider mortice chisels fit the brief perfectly. They incorporate a couple of refinements to make them easier to use and achieve better results.
Starting at the top, a steel hoop prevents the handle splitting from constant mallet blows. A small button of timber protrudes above the hoop to minimise damaging the mallet head. The handle is dense European Hornbeam chosen for its resilience. Sanded smooth and given a light oil finish, the Hornbeam has a superb feel in the hand. The handle ends in a polished stainless steel ferrule with a shock absorbing leather washer between the handle and the chisel’s bolster.
The forged blade is Cr-Mn steel and is heat treated to 59 HRC. The steel’s fine grain ensures a keen, long lasting edge. The bevel only requires honing before use. Although, you may wish to sharpen with a steeper secondary bevel, depending on the type of timber you are using.
Improved cutting performance comes from a slight taper in the cross section of the blade, the top being slightly narrower. There is a fractional taper in the length of the blade, less than 0.5mm over the entire length. These tapers give just enough clearance even in a deep mortice to stop the chisel binding in the cut. The blades are approximately 140mm long with the overall length 305mm. European made.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.61 44
