For our latest updates about delivery and stores, click here
£149.95 £124.96
Out of stock
- dispatch estimate is within 3 weeks. Delivery info
  • Blade bedded at 12° with bevel-up, superior finish on end grain
  • Ideal plane to use on a shooting board
  • 5mm thick high carbon steel blade eliminates chatter
Customers Also Bought
Total: £319.71
The No. 62 is a low angle jack plane. First produced in the dim and distant past by Stanley, it was originally intended for use on end grain and stock removal. The Stanley version had its faults though, namely the thin casting. Modern casting methods and design means the Axminster Rider No. 62 will bring you only positive results. The bed angle (12°), bevel-up blade, depth adjustment and adjustable mouth are all features reminiscent of superior block planes. The No. 62 performs exceptionally well when used on a shooting board. The 12° bed combined with a bevel angle of 25° gives you an effective cutting angle of 37°. The chunky blade is 5mm thick and able to slice through timber with ease without fear of chatter. The micro depth adjuster combined with an adjustable mouth gives you complete control to produce the thinnest of shavings and leave the silkiest of surfaces. One of the key features the No. 62 has over other bench planes is the easily adjustable mouth, meaning timber tear can be kept to a minimum. Grinding steeper bevels on the blade gives you the option of using the No. 62 for working difficult grain where tear-out could be a problem.
This Rider version has many excellent features. The main casting is a ductile iron alloy, chosen for its high strength and its impact and high corrosion resistant properties. The cap iron and other quality fittings on the planes are solid brass, an ideal material for moving parts. The sole is 350mm (14") long with a 50mm (2") wide, 5mm thick blade. The sole of the plane is flat and accurate. Weight 2.24kg (4lbs 15oz).
Rider planes only require the bare minimum of preparation. The blade comes honed with a secondary bevel ready to take shavings. Each blade is oil quenched, high carbon steel, hardened and tempered to HRC 63. Every plane undergoes careful inspection in Axminster to ensure consistent quality. The No. 62 comes with a spare blade and plane sock. We are confident that Axminster Rider planes represent a good standard of traditional, quality plane manufacture and great value.
  • Adjustable mouth for control in either light or heavy cuts
  • Ductile cast iron alloy body, brass lever cap, smooth wooden handles
  • Supplied with a spare blade and a plane sock
This product is on page 258 of the Axminster Tools Catalogue View Page 258
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
