Unlike common pointed tailstock centres, a Live Ring Centre eliminates the risk of splitting small section or brittle timber. The tip has a small point to help with alignment when mounting your work. Support comes from the raised ring or rim. A Live Ring Centre leaves only a small mark on the end of the workpiece. The body features sealed dust proof bearings for a long life turning on the lathe. The dimensions of the ring and point exactly match those of the Axminster Woodturning Ring Friction Drive.
Axminster Woodturning Ring & Centre Point Live Revolving Centre
| Made in Britain | Yes |
| Morse Taper | 1 MT |
| Intended Use | Plays a crucial role in securely holding the workpiece on a lathe. |
| Web Attribute Set | Live Tailstock Centres |
| EAN Barcode | 5052511012824 |
