This excellent rip fence upgrade is a godsend to anyone struggling with a worn or sub-standard bandsaw or table saw fence on an otherwise well performing machine. It is made from aluminium extrusions and features ball bearings for smooth running, adjustment for squareness, graduated scales and a quick action locking handle. The support rail fits to the front edge of the saw table with two brackets with holes positioned 23mm below the table surface. The brackets can be positioned along the length of the rail to suit different sized tables. If the table edge is not deep enough then simple angle brackets can be made to mount the rail. The length of the rail is 740mm and the fence is 550mm long by 65mm deep. The fence extrusion has tee slots on three faces for mounting false fences and other accessories. Altogether a very well-produced and effective accessory for upgrading your bandsaw or table saw.
Axminster Rip Fence Upgrade
| Web Attribute Set | Bandsaw Accessories |
| EAN Barcode | 5052511002399 |
