Axminster Small Rip Fence Upgrade
SKU: 100257
£19.98
£16.65 Excl. VAT
  • Rip fence upgrade for small bandsaws
  • Full fitting instructions supplied
  • Fence 370mm, rail 340mm long
A replacement, superior rip fence arrangement that will replace the flimsy fences found on many, low cost benchtop bandsaws. This is a very worthwhile upgrade that will make your machine more accurate to use. The fence is 370mm long and the rail 340mm. Some small modification work will be needed to adapt this to most machines, but this should not deter you from making this upgrade.
Web Attribute Set Bandsaw Accessories
EAN Barcode 5052511002672
