Axminster Engineer Series Super Precision Machine Vices
- Precision machine vices for all workshop applications
- Fully hardened (55+/-3HRC) ground steel jaws
- Parallelism of jaws within 0.0012" (30 microns)
- Vice rotates through 360° on base
- Close grained high tensile, seasoned cast iron bodies
- Two securing slots
High quality, precision machine vices for use on drill presses, mills and other similar machines. Bodies are made from close grained high tensile seasoned cast iron and have a scratch and rust resistant finish. The jaws, made from steel hardened to 55+/-3 HRC and ground with a parallelism of 0.0012" (30 microns), hold the workpiece dead square for perfect results. The vice bodies rotate horizontally 360° against a scale and can be locked securely in the set position. There are two slots for securing the vice to the machine table. Bodies are de-mountable from the circular bases. Available in two jaw sizes - 50mm wide by 25mm deep with 50mm opening and 75mm wide by 33mm deep with 75mm opening. Precision work holding and absolutely superb!
