£1,699.50 £1,416.25
In stock
- heavy goods delivery within 7-21 working days. Delivery info
  • Compact 254mm blade table saw
  • Cast iron ground surface table
  • Wide spaced, chassis mounted trunnion system for strength
Customers Also Bought
Total: £1,771.25
A compact yet capable saw,
offering complete accuracy with every cut
But, its capacity doesn’t stop there. With the option to add the compatible Dado Blade set, you’re also able to cut grooves.
Did someone mention Dado?
Made up of two TCT saw blades and six chipper blades, the Dado Blade Set is an optional accessory and enables you to achieve exceptional tongue and groove slots. The optional Overhead Crown Guard accessory ensures this feature complies with all current Health & Safety regulations. There is a quick release catch to make it simple to switch out the riving knife for the dado set.
Highly recommended
The use of the Overhead Crown Guard which ensures the blade is effectively guarded (please see the HSE website for additional guidelines).
Turn the saw into a small panel saw
The optional ST1400 Sliding Table has an exceptional 1400mm stroke and is 1200 x 230mm in size. A separate 335 x 230mm outrigger table comes with it offering extra support.
This compact table saw has a laser cut, welded steel chassis, supporting the entire workings of the machine on widely spaced trunnions. A cast iron frame supports the motor and blade arbor, giving plenty of rigidity and blade support. The blade height and tilt controls are very smooth in operation using the cast iron handles.
The ground surface cast iron table is completely stress free and has twin 19mm mitre fence slots, and a steel kerf plate that is adjustable to the table surface. There are phenolic RH side and rear extension tables, giving support for sheet materials during cutting. Removing the riving knife is tool free, release a simple latching pin and the riving knife is easy to remove by hand. The full length rip fence has a T-square style mounting, is fully adjustable, smooth sliding and rock solid when locked. A Hi-Lo sliding fence rail gives wide versatility. A cast iron mitre fence with pre-set angle stops is included.
Dust extraction is direct from the lower blade housing, with a cleverly designed crown guard directing airflow from the blade above the table. A single 100mm port allows easy connection to a suitable dust extractor.
Similar in design to the AT254TS, but designed for lighter duties in a small workshop, both in a trade or home environment. This table saw can be added to with several options, including a 1,400mm sliding table complete with a UJK sliding table fence, the S-12 Overhead Crown Guard System, and a Dado Blade Set.
  • Efficient extraction fro crown guard
  • Phenolic right hand side and rear extension tables
  • 1.65kW TEFC induction motor
  • Full length rip fence, cam locked and fully adjustable for accuracy
  • Super smooth blade adjustment and quick change riving knife
  • Optional sliding table, dado blades, overhead crown guard etc
This product is on page 8 of the Axminster Tools Catalogue View Page 8
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
