£2,859.50 £2,382.92
In stock
- heavy goods delivery within 7-21 working days. Delivery info
  • Compact 254mm blade table saw with deep section cast iron table
  • Wide spaced, chassis mounted trunnion system for strength
  • Cast iron right hand side extension table machined to take a UJK router plate
Customers Also Bought
Total: £4,483.38
Its strong, rigid and powerful body is only the start of this super smart saw
With new optional sets and accessories you're also able to rout and make dado cuts!
Did someone mention Dado?
Made up of two TCT saw blades and six chipper blades, the Dado Blade Set is an optional accessory and enables you to achieve exceptional tongue and groove slots. The optional Overhead Crown Guard accessory ensures this feature complies with all current Health &Safety regulations. There is a quick release catch to make it simple to switch out the riving knife for the dado set.
Highly recommended
The use of the Overhead Crown Guard which ensures the blade is effectively guarded (please see the HSE website for additional guidelines).
Use the table saw as a router table
The cast iron right hand extension table is recessed to incorporate a router table insert and is compatible with the UJK Router Fence, UJK Router Elevator or more basic UJK Router Insert.
Turn the saw into a small panel saw
The optional ST1400 Sliding Table has an exceptional 1400mm stroke and is 1200 x 230mm in size. A separate 335 x 230mm outrigger table comes with it offering extra support.
Upgrade to a Zero Clearance Insert
Replace the standard kerf plate with the Zero Clearance Insert. For use only when the blade is at 0°, it sits extremely close, a mere 0.5mm from the blade. As well as preventing the waste from dropping beneath the table it also helps support smaller work, allowing finer cuts.
The AT254TS shown fitted with optional accessories
This is a smart 254mm blade table saw with a very high build quality, and some features normally only found on much more expensive machines. Although of a conventional design, the exacting precision used during manufacture marks this machine out from others of a similar price. The whole design centres around a laser cut, heavy duty welded steel chassis, supporting the entire workings of the machine on widely spaced trunnions. This leaves the table completely unstressed and gives a superbly smooth control of the blade tilt and height.
Internally, a massive, curved iron casting supports the motor and blade arbor, giving huge rigidity and blade support. The deep section cast iron table has twin 19mm mitre fence slots, and a kerf plate that is adjustable to the table surface. The riving knife requires no tools to remove, a simple latching pin is released and the riving knife is easily removed by hand.
A cast iron right hand side extension table is provided, which can be used as a router table, and is machined to take a UJK 10mm router insert plate or UJK router lift. Twin grooves are machined into the extension table to mount the optional UJK RT-100 router fence.
The full length rip fence has a T-square style mounting, is fully adjustable, smooth sliding and rock solid when locked. A Hi-Lo sliding fence rail gives wide versatility.
This table saw can be added to with several options, including a 1,400mm sliding table complete with a UJK sliding table fence, the S-12 Overhead Crown Guard System, and a Dado Blade Set.
Supplied ready for use with a top quality TCT blade, this table saw will suit both the busy trade workshop or discerning home woodworker alike. N.B. 16A supply required. We recommend that the machine is hard wired to your power outlet.
  • 2.2kW TEFC induction motor
  • Full length rip fence, cam locked and fully adjustable for accuracy
  • Super smooth blade adjustment controls, quick change riving knife
  • Optional sliding table, router fence, dado blades, overhead crown guard etc
This product is on page 10 of the Axminster Tools Catalogue View Page 10
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
