Low Price
Special Price £1,099.98 £916.65 was £1,199.98 £999.98 Save £100.00 £83.33
Limited Stock
In Stock
- get it Friday 28th Jan, order within and choose Premium delivery. Delivery info
  • Max depth of cut 200mm, max width of cut 340mm
  • Deep section rip fence supported front and back
  • Micro adjustable ball bearing blade guides, easy to set
Customers Also Bought
Total:
£1,204.72 £1,003.93
Axminster Trade AT2552B Bandsaw
The AT2552B bandsaw, with its high specification and modest price, is a very popular sized machine for the trade or home workshop.
Strong and durable
The welded steel body helps to make the bandsaw rigid for additional stability and accurate cuts, while the twin trunnion table support helps reduce vibration during use.
Smooth cutting surface
The extra large cast iron table with precision ground surface ensures both added support and a hassle free cutting experience.
Supported front and back, the deep section rip fence allows you to enjoy full support when you’re ripping thicker pieces of timber.
Easier set up
Micro adjustable, ball bearing blade guides make setting up your bandsaw a simpler process than ever before, saving you both time and effort.
For added safety and security, there’s an adjustable T-slotted precision mitre fence. Plus, there’s also interlocked and micro-switched doors and an emergency stop switch to safeguard you while you work.
The combination of a rigidly built steel body, large and finely ground cast iron table, deep section rip fence and micro adjustable ball bearing blade guides produces the high level of performance demanded by both trade and amateur craftsmen. The rip fence runs on a calibrated aluminium extrusion and is locked firmly in place with a lever, giving a solid and accurate location. The adjustable precision mitre fence is T-slotted into the table for added safety and accuracy. The table tilt quadrants are set very widely apart to give the maximum support to the table and to make the tilt action very smooth. Cutting depth is controlled by a well engineered rack and pinion system, with a lock to set the guides into position.
At the rear of the machine are the blade tracking control, the blade tension indicator and a quick action blade tension lever, useful for both blade changing and for releasing the tension on the blade when the machine is not in use. The powerful induction motor transmits its power via a multi-groove flat belt, ensuring smooth running and zero slip. Safety features include interlocked and micro-switched doors and an emergency stop switch.
Beautifully made and sure to please. Supplied with floor stand, rip fence, mitre fence and a 6tpi bandsaw blade.
  • Welded steel body, extra large cast iron table, precision ground surface
  • Vibration-free balanced aluminium blade wheels
  • Adjustable, precision T-slotted mitre fence
  • Supplied with floor stand, rip fence and blade
Warranty Trade Classification & 3 Year Guarantee
Buy with confidence
Machine Classification
3 Year Guarantee
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPay By FinanceHitachi Pay by Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
