Axminster Trade AT3352B Bandsaw
- Max depth of cut 350mm, max width of cut 360mm
- Precision ground and TiN coated large cast iron table
- T-square style fence maximises accuracy, has complete adjustability for aligning to blade
Customers Also Bought
The Axminster Trade AT3352B Bandsaw is among the very best premium 350mm deep cutting bandsaws on the market.
The welded steel frame is over-sized with extraordinary rigidity, allowing very high blade tensions. The machine has a 230V 2.2kW 1ph smooth and powerful mechanically braked motor, giving more than adequate drive. The large cast iron band wheels give extra inertia and are balanced for smooth running. Uniquely, the precision ground cast iron table has a titanium nitride (TiN) coating, which apart from looking great, creates a smooth surface and protects the table from rust.
Worm gear systems for both table tilting and blade guide post movement are used for easy adjustment. Tool-less upper and lower blade guides give you quick and easy setting. A T-square rip fence bracket with full adjustment ensures that the fence rail is set accurately to the blade. The switch system has a brake-off setting to allow easy blade changing and setting. A locking key switch is fitted. Unusually, there is a foot brake provided, giving an additional method of quickly stopping the machine if your hands are full of timber! Door safety protection, 4-sided blade guard, quick release blade tensioning, high/low tall fence, dual 100mm dust ports and high re-saw capacity are all additional features of this bandsaw.
N.B. 230V 16A supply outlet required, plug fitted on the machine.
- Worm geared trunnion system for table tilt to 45°
- Extra large aluminum fence plate providing high/low cuts
- Blade guides with tool-less adjustment for extra stability and accuracy
- Cast iron, balanced wheels
- 4-sided blade guard providing complete security
