Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Trade AT430DS Drum Sander
Code: 105584
  • Compact, single drum sander for finishing all timbers
  • Solid welded steel construction, cast iron table
  • Variable speed feed system for varying finishes
  • Thick, rubber conveyor belt, feeds work evenly
  • Quick release abrasive clips
  • Wide range of abrasives available
  • Fully adjustable to maintain superb accuracy
  • Show More
£1,699.98 (£1,416.65 Ex. VAT)
Low stock - get it tomorrow, Tuesday 2nd Jun, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Trade Classification & 3 Year Guarantee
It's not often that such a small machine has impressed so much, but this small sander has done just that. Firstly, it is very well made, of solid construction with attention to detail down to the smallest component. It is designed for finishing panels or square timbers and can take a panel up to 430mm wide or timber up to 100mm high.
Powered by a 750W induction motor, with a separate 90W variable speed conveyor motor it offers plenty of control over the finish. The conveyor is made from soft, high grip rubber which will not mark the work. A crank handle controls the height of the conveyor, with a scale giving an indication of its setting.
The sanding drum takes strips of 76mm wide abrasives; there is a wide range to choose from to suit all tasks. Quick release clips secure the abrasive, with one being spring-loaded to accommodate stretching of the abrasive to a small degree. Dust extraction is very important, a single dust port effectively removes the waste when connected to a suitable extractor.
A compact machine supplied with a sturdy stand, it will not take up much space and will complement many workshops. This is probably the perfect machine to use with a thicknesser, removing those small imperfections before applying a finish.
Information Downloads
Promo
This product is on page 73 of the Axminster Tools & Machinery 2019/20 Catalogue.
Specification
Specification
Abrasive Roll Width 76 mm
Dust Extraction Outlet 100 mm
Feed Speed 0 to 6 m/min (var)
Model AT430DS
Nett Weight 94 kg
Overall L x W x H 600 mm x 755 mm x 1,180 mm
Power 750 W
Rating Trade
Sanding Drum Diameter 125 mm
Sanding Thickness Min\Max 1 mm to 100 mm
Sanding Width Single Pass 430 mm
Sound Power Level [Uncertainty K] 72 dB(A)
Table Size 600 mm x 435 mm
Voltage 230 V
Plug Fitted UK 3 pin plug
Drum Speed 1,720 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
