Axminster Trade ATG700DP Gyro Air Fine Dust Processor
- 99.9% dust separation efficiency before filtration
- Very low noise, 61-76db(A)
- Compact size with built-in mobility kit
Customers Also Bought
The Axminster Trade ATG700DP Gyro Air is a different kind of dust extractor. Traditional cyclone dust extractors separate dust from the air stream by gravity and need a bin for large particles and a bag for fine dust. In addition, the filters need regular cleaning to maintain performance.
The ATG700DP Gyro Air spins the debris-laden air at approximately 4,000rpm within twin stainless steel double cone separation chambers. The centrifugal force pushes the dust particles out from the airstream into the dust containers. The air stream exiting the separation chambers is 99.9% free of waste dust as it passes through the filters. In actual fact, the filters have very little to do. The technology does not stop there; a Siemens V20 inverter controls the motor speed. Regulating the speed adjusts the airflow to tailor it to suit a particular application.
The overall design is compact and mobile; making it easy to move the extractor from job to job. The waste collection bins are easy to empty, cleverly coming out on rails from inside the machine.
The ATG700DP Gyro Air offers new waste management technology for the modern workshop.
- Strong and constant static pressure for efficient waste collection
- Up to 50% energy saving by using the variable speed control
- Intelligent "dust full" waste bin monitor
