The Axminster Trade Clamps range includes clamps for use in woodwork, engineering, fabrication and welding. Designed for both trade and professional use, they are guaranteed to give you maximum performance and, with active clamping, maximum pressure. You can never have enough of the right clamps!
The jaws are robust aluminium alloy on a 20 mm x 6 mm steel bar. These die-cast jaws are capable of applying substantial pressure to the workpiece. Squeezing the handle advances the moving jaw. The spring-loaded face is slightly angled so its top touches first as the jaws close. As pressure is applied, the spring compresses to ensure even pressure distribution, even on slightly tapered surfaces. The fixed jaw is reversible to convert the clamp quickly into a spreader. The jaw faces have non-marring, glue-resistant pads and the clutch operates with a simple release. All sizes – 160Kg max clamping pressure.
Lifetime Guarantee.
Spring-loaded jaw face ensures even pressure distribution
Ideal for using on slightly tapered surfaces
Reversible fixed jaw to convert the clamp into a spreader
Robust aluminium alloy construction; throat depth of 80mm
