Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Trade Clamps Aluminium Sash Clamp
  • High clamping pressure of 250Kgs
  • Jaws toe'd in for maximum pressure transfer
  • Low weight-high force clamps 1.5 - 250 Kgs
  • Rigid aluminium construction, corrosion resistant
  • Spreader function
  • Show More
NOW £24.95 - £31.67
Normally from £29.95
(£20.79 - £26.39 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
These sash clamps exhibit a high clamping force of 2500 Newtons (250 Kgs in easy understand terms) yet weigh in at 1.1 kgs - 1.5Kgs in weight per clamp typically adding 6Kgs when used in 4's clamping up panels. The jaws have an intentional "toe in" that angles the jaws slightly inwards so that under pressure the wood has a minimal force down into the clamp. Under maximum pressure, all clamps will bow slightly especially when used at their maximum capacity even with this bow the toe in will compensate for the angular movement of the jaw face. In most instances, these clamps work exceptionally well by placing two on one side of the work and two on the opposite side. Large rubber-faced pads on the jaws protect the work from the pressure applied by the jaw, these pads can be easily removed if needed. Unlike much heavier steel clamps the aluminium bar does not react with any glue excess marking timbers such as oak etc. For certain applications, the active clamp head can be removed and reversed to create a spreading clamp.
These clamps come highly recommended they are well made, versatile in use and have a high clamping pressure of 250Kgs per clamp.
Promo
This product is on page 238 of the Axminster Tools & Machinery 2019/20 Catalogue.
Learn more about "toe in"
The jaws have an intentional "toe in" for maximum pressure transfer.
The jaw is tilted inwards. Because the force/pressure is perpendicular to the toe-in angle this feature, found on many woodworking vices and clamps, helps to avoid the problems of racking (the tendency of the wood and the bar to bend upwards when under pressure).
Download a PDF version
Specification
Specification
Clamping Pressure 250 kg
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
