Axminster Professional HD G Clamp
- Large clamping capacities and high clamping pressure
- Drop forged, for maximum strength
- Suitable for woodwork, fabrication and engineering
See the entire rangeThis range of Axminster clamps is heavy duty, with bigger capacities and far greater clamping pressures. They feature drop-forged bodies, large clamping faces and a square rolled thread for extra strength.
Lifetime guarantee.
100 mm x 55 mm – 580Kg max clamping pressure
150 mm x 70 mm – 680Kg max clamping pressure
200 mm x 90 mm – 840Kg max clamping pressure
250 mm x 100 mm – 925Kg max clamping pressure
