This quick action clamp has a specially designed spigot to fit into the slot on the underside of a power tool guide rail. The spigot is compatible with the following guide rail systems, amongst others: Festool FS, Makita, Milwaukee, DeWalt, Kreg and Rigid. To be sure, please check the clamp slot in your guide rail prior to ordering. The spigot is 11mm wide by 4mm thick and 60mm long. Clamps supplied singly.
Owners of multi function workbenches can use the clamp as a hold-down simply by inserting the spigot into a dog hole. The single-handed operation leaves one hand free to steady the workpiece. The moving jaw has a resilient protective pad to prevent damage to delicate surfaces.
Clamp Throat Depth 60 mm
Clamping Capacity 160 mm
Warranty Axminster Clamps Lifetime Guarantee
EAN Barcode 5052511107995
