These extra heavy duty clamps have strong 20 mm x 45 mm cold drawn steel bars. The T-section effectively eliminates twisting or bending under pressure. The bars also have a unique, chemically blackened surface to resist corrosion. The powder coated, ductile cast heads have 50 mm x 50 mm clamping faces. Other features are the twin start screw thread and 125 mm long tommy bar for fast adjustment countersunk holes in the base of the head allow for fixing to the bench if desired. Max clamping pressure - 800Kg.
Lifetime Guarantee.
Heavy duty, strong T-section bar, 20mm x 45mm in overall section
Grey ductile cast iron head and tail, 50mm x 50mm clamp faces
Twin start screw thread; max clamping pressure - 800Kg
