Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Trade Honing Guide
Code: 720742
  • A comprehensive bench plane blade and chisel honing guide
  • Guarantees accurate and precise bevel angles
  • Setting for bevels anywhere between 20° and 40°
  • Clear scale, permanently etched in 1° increments
  • Wide roller guarantees stability and prevents undue stone wear
  • Accommodates blades from 6mm to 66mm
  • CNC machined mainly from stainless steel
  • Supplied with setting jig for perfect results every time
  • Show More
£94.90 (£79.08 Ex. VAT)
Out of stock - dispatch estimate is within 1 week.
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
The Axminster Trade Honing Guide Assembly for the Ultimate Edge coupled with the Micro Bevel Guide forms a very precise stand-alone honing guide.
The unique feature of this combination is the high level of accuracy and control it offers. Using a bench or diamond stone, you can sharpen all your chisels and bench plane blades with the bevel angle of your choice from a shallow 20° to a steep 40°. After establishing the primary bevel, you can add a micro bevel from as little as 1°, although around 5° is the generally accepted norm.
The Plane Blade Honing Guide is perfect for plane blades, bevel edge, mortice and Japanese chisels. The jaws are slightly undercut dovetail to ensure secure clamping of a blade or chisel against the body. The jaws can accommodate blades or chisels from 6mm to 66mm wide. The left-hand jaw is reversible, one side straight and the other slightly curved enabling you to clamp chisels with unparallel sides equally securely.
Both parts are predominately stainless steel and precision made on CNC machines in Axminster’s own manufacturing facility.
Set-up could not be easier, based on a blade projection of 25mm the guide includes a small setting jig. The degree scale is clear and easy to read with the markings permanently etched. The wide roller ensures perfect stability and at the same time prevents undue stone wear if you are using a Japanese water stone.
This guide can accommodate a wide variety of blades in a wide range of sizes and guarantees precise results every time.
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
