£1,229.50 £1,024.58
In stock
- heavy goods delivery within 7-21 working days. Delivery info
  • Trade rated planer thicknesser substantially constructed from cast iron and welded steel
  • Cast iron tables and tilting alloy fence offer exceptional accuracy and stability
  • 3-knife cutter block gives a very clean finish to the work
Customers Also Bought
Total: £2,646.50
This is a nicely designed planer thicknesser, especially suited to the trade workshop or discerning home user. Constructed from cast iron and heavy gauge welded steel, it is robust and will withstand heavy usage on a daily basis. The cast iron surfacing tables have heavy ribbing underneath to maintain flatness and, unusually, both tables are completely adjustable to the blades to avoid sniping. The tables hinge independently and have up-stop latches to hold them securely when thicknessing. The thicknessing table is easy to adjust with a smooth mechanism and it has a position lock which prevents any movement. The 3-knife cutter block has quick change HSS knives as standard; these are self-setting, razor sharp and will give a superb finish. There is a power feed engagement lever for use when thicknessing; the 5m/min feed speed ensures a smooth, even finish. When surface planing, the long rigid alloy fence supports your work securely, the fence being easily adjustable with stops for 90° and 45°. Brackets are mounted on the rear of the machine to store the fence when not in use. Chip extraction is via a hinging flip-over hood which is electrically interlocked for safety.
Also available is a version (101156) fitted with a spiral blade cutter block. This uses 15mm x 2.5mm 4-sided TCT spur type cutters, 44 in all arranged over four rows. These cutters are unique in that the edges are machined to a radius of 102mm; this coupled with how they are set on the block means that a shear type cut is achieved. There are several advantages of this type of cutter block. Durability: each edge will last around 10-20 times longer than a HSS knife and you have four edges per cutter. Noise: spiral cutter blocks are notably quieter in use, up to 50% with some timbers. Power: because of their shear type cutter action, the power saving can be as much as 30%, meaning much less strain on the machine and lower running costs. Your extraction will be more efficient because of the even shape of the chips, packing more into the waste sack. The spiral blade cutter block versions are also supplied with digital height indication of the thicknessing table.
If your work involves machining difficult, abrasive timbers, or large batch production with sanding as a finishing procedure, then this system is unbeatable. And the finish is silky smooth, without the traditional fine lines across the board.N.B. 16A supply required, type C breaker recommended.
  • Supplied with 1mm self-setting HSS knives
  • Pivoting dust extraction hood operates in thicknessing and surfacing modes
  • Both tables are adjustable and electrically interlocked for safety
  • Extended support roller on thicknessing table
  • Spiral cutter block version also available (101156), using unique "shear cut" knives
This product is on page 49 of the Axminster Tools Catalogue View Page 49
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
