Update: all our stores are currently open for Click & Collect only - find out more
£2,549.98 £2,124.98
Out of stock
- large delivery dispatch estimate is within 6 weeks. Delivery info
  • Trade rated planer thicknesser substantially constructed from cast iron and welded steel
  • Spiral block with shear cutting action gives a very clean finish to the work
  • Uses 15mm solid Tungsten Carbide four edged spur cutters
Customers Also Bought
Total: £2,816.12
Why go spiral?
A smoother finish with a longer life, less noise and more efficiency? The question is, why wouldn't you go spiral?
This is a ruggedly made planer thicknesser, especially suited for use in any trade workshop. Constructed from cast iron and heavy gauge welded steel, it is robust and will withstand heavy use on a daily basis. The long cast iron surfacing tables have heavy ribbing underneath to maintain flatness and, unusually, both tables are completely adjustable to the cutter block to avoid sniping. The tables hinge independently and have up-stop latches to hold them securely when thicknessing. The thicknessing table is easy to adjust with a smooth mechanism, and is also supplied with digital height indication for accurate measurement of the cut. A position lock is fitted which prevents any movement. There is a power feed engagement lever for use when thicknessing; the 6m/min feed speed ensures a smooth, even finish. When surface planing, the long rigid alloy fence supports your work securely, the fence being easily adjustable with stops for 90° and 45°. Brackets are mounted on the rear of the machine to store the fence when not in use. Chip extraction is via a hinging flip-over hood which is electrically interlocked for safety.
In line with the intended professional use, the machine comes fitted with a four-row spiral cutter block. The advantage of this type of block is the immense amount of time it can save. The block features fifty-six, 15mm square solid tungsten cutters arranged in a helical pattern. When the cutters eventually dull, it is a simple matter of rotating each one to a fresh edge. Each edge lasts over ten times longer than HSS, and each cutter has four edges; tricky knife changes, sharpening, setting and checking are things of the past. There are several advantages of this type of cutter block :-
Durability: each edge will last around ten times longer than an HSS knife and you have four edges per cutter.
Noise: spiral cutter blocks are notably quieter in use, up to 50% with some timbers. And the finish is silky smooth, without the usual lines across the board.
Power: because of their shear type cutter action, the power saving can be as much as 30%, meaning much less strain on the machine and lower running costs.
Your extraction will also be more efficient because of the even shape of the chips, packing more into the waste sack.
If your work involves machining difficult, abrasive timbers, or large batch production with sanding as a finishing procedure, then this system is unbeatable. N.B. 16A supply required, type C breaker recommended.
  • Long cast iron tables and tilting alloy fence offer exceptional accuracy and stability
  • Pivoting dust extraction hood operates in thicknessing and surfacing modes
  • Both tables are adjustable and electrically interlocked for safety
  • Extended support roller on thicknessing table
This product is on page 44 of the Axminster Tools Catalogue 2020/21 View Page 44
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
