Update: all our stores are currently open for Click & Collect only - find out more
£999.98 £833.32
In Stock
- get it Thursday 4th Mar, order within and choose Premium delivery. Delivery info
  • Heavy cast iron construction gives strength and low vibration
  • Inverter drive controls the motor speed and torque
  • LED spindle speed read-out in rpm for great control
Customers Also Bought
Total: £1,306.22
Compact yet capable; take your woodturning to the next level
Flexibility and versatility - supplied as a bench top model only, you’re able to tailor the lathe
to suit your needs with optional accessories.
Lathe Stand
Made from box section steel, it is simple to assemble and sturdy. It is adjustable in height from 610mm-875mm and so creates a comfortable working height. The feet are splayed back to give plenty of foot space.
Find out more
Tool Rest System
The Axminster Woodturning Tool Rest System is made entirely of stainless steel for the smoothest turning. The chisel glides seamlessly across the rounded bar without any nicked interruptions.
Find out more
Evolution SK114 Woodturning Chuck
Made in Axminster using CNC technology, the Evolution chuck is a revolution in chuck making. It’s slim design keeps the weight of your work over the bearing, giving you greater control and less vibrations. Its stainless steel body also prevents it from rusting meaning it’ll last and last.
Find out more
The AT350WL utilises the very reliable inverter technology usually found on much larger machines. Electronic variable speed is a desirable feature for woodturners, enabling fine tuning of speed to suit delicate work, larger diameters or out of balance work pieces. A three step poly-V pulley system allows three speed ranges which coupled with the load sensing inverter ensure maximum torque and stable spindle speeds. The magnetic backed switch unit can be placed on any convenient position on the lathe bed or headstock to suit the work in hand. It incorporates on/off buttons, a speed control knob and a forward and reverse switch. An LED digital read-out of the spindle speed in RPM is a useful feature that helps control your work. A 400mm(16") between centres and a 350mm (14") swing over the bed capacity is generous on a lathe this compact. Spindle indexing is achieved in 15° segments by insertion of a magnetic dowel pin. Threaded holes (3/8"x16 UNC) are provided at each corner of the lathe for bench mounting. Tool post diameter 1" (25.4mm). This lathe has proved to be very popular for both teaching and craft demonstrations, not too big nor heavy but with enough capacity to show off your skills. Supplied with four prong Axminster drive centre, Axminster revolving tailstock centre, 75mm faceplate and a centres knock out bar.
N.B. The distance between centres will vary and be dependent on the type of centres or accessories used.
This machine was previously known as the AT1416VS.
  • Forward and reverse capability, perfect for final sanding
  • Versatile magnetic switch mounting for optimum positioning
  • 24 position spindle indexing, position held by magnetic dowel pin
  • Supplied with Axminster drive and revolving tailstock centres
This product is on page 326 of the Axminster Tools Catalogue 2020/21 View Page 326
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
