Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Trade AT406WL Bench Mounted Woodturning Lathe
Code: 502703
  • Large capacities for such a compact sized lathe
  • Thick cast iron sections for strength and vibration free running
  • 1.5kW motor with inverter speed control and two belt speed ranges
  • Digital spindle speed readout in rpm, gives great work control
  • 2MT internal tapers in headstock and tailstock
  • Spindle thread M33 x 3.5mm, many accessories available
  • Forward and reverse facility, perfect for final sanding
  • Magnetic control box can be positioned on the lathe where required
  • Show More
£1,599.96 (£1,333.30 Ex. VAT)
In stock - heavy goods delivery within 7-21 working days
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
Heavy Goods
  • UK mainland - free
  • UK remote - charge advised in basket
This bespoke service includes off-loading and assistance where practical. Our delivery experts will contact you to arrange a convenient delivery date.
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Axminster Trade AT406WL Bench Mounted Woodturning Lathe
  • Axminster Trade Stand for AT406WL/AT1628VS Lathe
  • Axminster Trade Bed Extension for AT406WL/AT1628VS Lathe
  • Axminster Evolution SK114  Chuck - M33 x 3.5mm
Total: £2,311.87
Description
In Detail
Trade Classification & 3 Year Guarantee
The AT406WL is a medium sized woodturning lathe from our Trade Series range and it is a very popular choice among discerning woodturners. We are so impressed with its quality and performance that we decided to equip our Skill Centre with several of these lathes as soon as we could. Supplied as a bench top model with the option to purchase a leg stand if required, the lathe and leg stand are of heavy cast iron construction to minimise vibration. The AT406WL features electronic variable speed supplied via an inverter with two speed ranges for maximum torque at low speeds. The advantage of variable speed is that you can fine tune the speed of the lathe to the work in hand. This is especially important when turning large or out of balance workpieces and it is so convenient for fast speed changes. Spindle indexing is provided at 10° intervals and a magnetic control console with start/stop, speed control and forward/reverse can be conveniently positioned for the work in hand. Everything about the lathe feels just right, with cam-lock action of the tool rest banjo and tailstock, all controls work smoothly and effortlessly. A swivelling headstock can be very useful, especially if bench mounting the lathe but it will also slide along to the tailstock end of the bed. This allows the turning of larger diameter bowls and platters off the end of the bed and increases the capacity considerably. A 460mm bed extension kit is available as an optional extra and this can be bolted onto either end of the lathe bed. If you have the lathe fitted to the cast iron leg stand it can also be attached in a lower position offering an impressive 875mm swing over the bed. This is achieved by moving the tool rest banjo down onto the bed extension and fitting the tool rest extension post supplied with the bed extension kit. If you are serious about your woodturning and want a lathe that offers excellent performance, features and value, this lathe would be a sound choice. Supplied with Axminster four prong drive centre, Axminster revolving tailstock centre, centre alignment bar,150mm (6") faceplate and a knockout bar.
N.B. The distance between centres will vary and be dependent on the type of centres or accessories used.
This machine was previously known as the AT1628VS.
Information Downloads
Promo
This product is on page 326 of the Axminster Tools & Machinery 2019/20 Catalogue.
Axminster Evolution Chuck
Compact yet capable; take your woodturning to the next level.
Flexibility and versatility
Supplied as a bench top model only, you’re able to tailor the lathe to suit your needs with optional accessories.
Lathe Stand
Lathe Stand
Sturdy cast iron design helps prevent vibration whilst the unique built in webs in the casting enable you to build custom made shelves if required.
Bed Extension
Bed Extension Kit
Expand the capacity between centres, the bed extension can be fitted to either ends of the lathe bed. Plus, with the lathe fitted to the cast iron leg stand, and the extension in its lower position, it offers an 875mm swing.
Chuck production
Evolution SK114 Woodturning Chuck
Made in Axminster using CNC technology, the Evolution chuck is a revolution in chuck making. It’s slim design keeps the weight of your work over the bearing, giving you greater control and less vibrations. Its stainless steel body also prevents it from rusting meaning it’ll last and last.
Tool Rest
Tool Rest System
The Axminster Evolution Tool Rest System is made entirely of stainless steel for the smoothest turning. The chisel glides seamlessly across the rounded bar without any nicked interruptions.
Find out more
Specification
Specification
Distance Between Centres 710 mm
Headstock Taper 2 MT
Max Diameter over Bed 406 mm
Model AT406WL
Nett Weight 96 kg
Overall L x W x H 1,650 mm x 480 mm x 550 mm
Power 1.5 kW
Rating Trade
Spindle Thread M33 x 3.5 mm
Tailstock Taper 2 MT
Voltage 230 V
Lathe Speed 50 - 1,250 / 150 - 3,750 rpm (var)
Tool Post Diameter 25.4 mm (1")
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
