For our latest updates about delivery and stores, click here
£2,999.95 £2,499.96
In stock
- heavy goods delivery within 7-21 working days. Delivery info
  • Heavy duty all cast iron construction for massive stability
  • Headstock slides and rotates on the bed for ease of use
  • 2.2kW variable speed inverter drive motor gives a wide speed range and high torque
Customers Also Bought
What makes the AT2030VS so versatile?
The supplied bed extension can be used in three different positions; all manner of woodturning projects can be turned without limitations.
Extendable bed
The bed extension can be mounted on one side of the main bed, and on each end or the stand; making it easy to switch between different sized projects with simple changes to the lathe bed.
Versatile headstock
The added benefit of the extended nose and chamfered edge of the headstock means you get access behind the back of your project much more easily than other lathes.
Iron construction
Made almost entirely of cast iron it has excellent stability and virtually no vibration.
Great precision
Large lathe but equally capable of producing small projects accurately with great precision.
Total: £3,116.16
This is the largest in our Trade Series woodturning lathes. It has all the features a serious woodturner would need for almost any woodturning project, large or small. Made almost entirely in cast iron, with the bed being particularly wide and well braced. Cast iron stand legs are included, providing a stable platform for the lathe. Vibration is virtually undetectable due to the mass of cast iron employed in the construction.
Unusually, this lathe can be used with the bed either way around, this is because the extension bed can be mounted either on the end of the main bed to extend the distance between centres, on the stand to create a bigger turning diameter, or on a mounting plate machined onto the side of the bed. This allows bowl turning with the headstock rotated to suit. The headstock can be slid totally along the bed and swivelled through 360° with indexing stops every 45°.
The headstock spindle is driven through a 10-groove multi V belt with a choice of three ratios; this coupled with the variable speed function gives a very wide speed range of 60-3,700 rpm. A remote control box with a magnetic back can be placed wherever you want and allows easy control. A forward and reverse direction switch is also fitted. The spindle has 24 indexing positions, held by a threaded stop pin. A separate spindle locking pin is provided, with a handy magnetic base.
The tailstock has an exceptionally long ram travel of 135mm, is etched with a scale and is unusually fitted with a digital readout, useful for precision hole boring. A long cam clamp lever locks the tailstock firmly in place and is easy to adjust. The tool rest holder has a wide base with an offset stem socket for increased rigidity. Two tool rests are provided, 150 and 300mm.
This is a top quality, fully featured lathe for the serious woodturner. With this machine in your workshop there would be very few woodturning projects you could not undertake.
Although a bed extension is included, you can purchase an extra bed extension, 104745.
N.B. The distance between centres will vary and depend on the type of centres or accessories used.
This machine was previously known as the AT2030VS.
  • 24 position spindle indexing, digital spindle speed readout
  • Supplied bed extension can be used in three positions for bowls or long spindles
  • Tailstock ram has digital position readout for precision working
This product is on page 327 of the Axminster Tools Catalogue View Page 327
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
