Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Trade AT700PD Floor Pillar Drill
Code: 102554
  • Medium sized, floor standing pillar drill for trade use, all cast iron construction
  • Smooth running 750W induction motor, 12 belt speeds 120-2,580rpm
  • Spindle running in genuine NSK ball bearings
  • Quill assembly is a good fit into the headstock
  • Convenient rack and pinion table height adjustment
  • Fitted with cast iron feed handle with soft rubber grips and a quality 1-16mm keyless chuck
  • Electrically interlocked chuck guard and LED work lamp included
  • Features include belt cover safety switch and separate emergency stop switch
  • Show More
£577.50 (£481.25 Ex. VAT)
In stock - heavy goods delivery within 7-21 working days
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
Heavy Goods
  • UK mainland - free
  • UK remote - charge advised in basket
This bespoke service includes off-loading and assistance where practical. Our delivery experts will contact you to arrange a convenient delivery date.
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Axminster Trade AT700PD Floor Pillar Drill
  • Axminster Unigrip Vertical/Horizontal Drill Vice - 125mm
  • Axminster Trade AT2552B Bandsaw
Total: £1,539.95
Description
In Detail
Trade Classification & 3 Year Guarantee
This is a medium sized, floor standing Trade pillar drill. Very robustly made from cast iron and machined steel giving high strength and stability. It has a highly accurate chuck spindle assembly, running in NSK ball race bearings. The quill housing is a good fit within the headstock casting, giving consistent drilling. Powered by a smooth running 750W induction motor, there are 12 belt speeds between 120-2,580rpm. The Japanese made belts are of the multi-vee type, chosen for maximum grip and the lowest level of vibration. The belt cover also has a safety switch to prevent the drill being run with the cover open. The down feed is via a one-piece cast iron handle with soft rubber grips and there is an accurate drilling depth control. A quality 1-16mm keyless chuck is fitted. The chuck guard is electrically interlocked for safety and is easily adjustable for height. The switch system has a separate locking emergency stop switch, plus there is a switch for the integrated LED work light. Table height is controlled via a rack and pinion system; the whole table assembly can be swivelled away to allow the base to be used as a work support. This trade rated pillar drill offers many unique features but is quite compact in size. If you are looking for a bench mounted model of similar size, please refer to product code 102553. A great choice for any trade or school workshop looking for a great performing floor standing pillar drill. Please note, this machine must be bolted to the floor for safe working.
Information Downloads
Promo
This product is on page 107 of the Axminster Tools & Machinery 2019/20 Catalogue.
Specification
Specification
Base Size 520 mm x 320 mm
Chuck Capacity 1 mm to 16 mm
Chuck Travel 80 mm
Chuck Type keyless
Diameter of Column 80 mm
Max Chuck to Base 1,150 mm
Max Chuck to Table 700 mm
Max Drilling Mild Steel 25 mm
Model AT700PD
Morse Taper 2 MT
Nett Weight 108 kg
Overall L x W x H 750 mm x 430 mm x 1,650 mm
Power 750 W
Rating Trade
Speed Range 120 - 2,580 rpm (12)
Spindle Taper 2 MT
Table Size 345 mm x 345 mm
Table Tilt 45° - 0° - 45°
Throat Depth 216 mm
Voltage 230 V
Plug Fitted UK 3 pin plug
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
