Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Trade AT315SB Saw Bench
Code: 501197
  • Compact 3kW 315mm table saw for trade use
  • All cast iron ground surface table with heavy-duty sheet steel base
  • 315mm TCT blade gives 100mm cutting depth
  • Sheet steel side support and rear feed off tables included
  • Optional right hand extension tables give 1,350mm max width to fence
  • Optional sliding table kit for crosscutting up to 1,220mm
  • Requires 16 amp supply, plug fitted
  • Show More
Save £129.54
Last Few
NOW £1,149.96
Normally £1,279.50
(£958.30 Ex. VAT)
In stock - heavy goods delivery within 7-21 working days
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
Heavy Goods
  • UK mainland - free
  • UK remote - charge advised in basket
This bespoke service includes off-loading and assistance where practical. Our delivery experts will contact you to arrange a convenient delivery date.
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Axminster Trade AT315SB Saw Bench
  • Axminster Trade AT315SB Table Extension Set
  • Axcaliber Premium TCT Saw Blade 305mm x 3.2mm x 30mm x 96T
  • Axminster Tools & Machinery Catalogue 2019/20
Total: £1,574.41
Description
In Detail
Trade Classification & 3 Year Guarantee
The Axminster AT315SB 315mm Saw Bench is a proven design robustly constructed largely from cast iron and heavy gauge sheet steel. It has large cutting capacities and is a good choice for the trade workshop. The 315mm blade gives a cutting depth of up to 100mm and is amply powered by a 3kW 1ph induction motor. The cast iron table gives great strength and rigidity as well as providing a smooth working surface. The rip fence is full length and is cam locked solidly onto rails at the front and back of the table. It also has a sliding sub fence to make rip work safer and is also provided with a micro positioning adjustment to ensure accurate measurement. A mitre fence slides in a choice of T-slot grooves in the table either side of the blade. Both the blade height and tilt controls have decently large handles, are conveniently located and lock in position.
The standard saw has a steel right hand side support table included, this gives 650mm cut to the fence, allowing full sized boards to be cut lengthways. A pressed steel feed-off table is also supplied. Dust extraction is provided with a 63mm hose on the crown guard leading to a combined 100mm dust outlet for efficient dust control when connected to a suitable high volume extraction system. A side access door is fitted to give easy access for maintenance. Supplied with an Axcaliber 60T TCT general purpose blade. Please note: a 16amp supply will be required, plug fitted. This machine is compact in size but ready for work in the home or light trade workshop.
Further options are available: (1) a kit of two cast iron extension tables that can be fitted either one each side or both to the right of the blade, complete with longer fence rails; (2) a fully functioning sliding table kit to allow large board materials to be cut. When both options are fitted this saw bench becomes a very versatile machine for most jobs in the workshop.
Information Downloads
Promo
Specification
Specification
Blade Diameter 315 mm
Blade Tilt 0° to 45°
Bore Size 30 mm
Dust Extraction Outlet 100 mm
Max Ripping Width 635 mm
Max Width of Cut with Fence 1,160 mm
Min Extraction Airflow Required 1,000 m³/hr
Model AT315SB
Nett Weight 215 kg
Overall L x W x H 2,030 mm x 840 mm x 865 mm
Power 3.0 kW
Rating Trade
Sound Power Level [Uncertainty K] 84 dB(A)
Table Height 865 mm
Table Size 800 mm x 870 mm incl side table
Table Size With Extensions 800 mm x 1,480 mm
Voltage 230 V
Max Depth of Cut @ 45º 75 mm
Max Depth of Cut @ 90º 100 mm
Blade RPM 4,000 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
