£1,369.50 £1,141.25
In stock
- get it tomorrow, Thursday 6th Aug, order within and choose Premium delivery. Delivery info
  • Trade rated benchtop bandsaw, high quality construction, extremely versatile
  • Inverter motor drive gives a wide blade speed, can cut metals with a suitable blade
  • Heavy gauge welded steel body, deep section cast iron table with ground surface
Customers Also Bought
Total: £1,460.18
This benchtop bandsaw is made to exacting standards to encompass all the features found on top quality floor standing machines. Designed in house, we set out to create a bandsaw with many unique features. The one piece frame is made from heavy gauge welded steel and is extremely rigid to withstand high blade tensions. A cast iron deep section table is fitted, featuring a ground table surface and a rack and pinion tilt mechanism with indexing stops for common angles. The heavy gauge alloy rip fence is mounted on a cast alloy bracket which also incorporates a fine width adjustment. The fence is clamped with a cam action lever, easily released to allow swift adjustment. Blade guides are all ball bearing with micro adjustment for accurate control. The top guide is mounted on a steel hexagon bar for stiffness and adjusted for height by a small rack and pinion system. A pair of cast iron band wheels, nicely machined and balanced are driven by a multi V belt with a choice of two ratios. The 750W induction motor features an inverter drive to control the motor speed. This gives a speed range of 42-1001 m/min. By using the lower belt speed and reducing the motor speed, this machine can be used for cutting some types of metal, for example by using a fine pitch M42 blade this bandsaw will handle mild steel plate from 2 to 10mm thick. Thinner or harder materials such as stainless steel cannot be cut in volume on this bandsaw. This model is a true all round machine, suitable for many kinds of projects using all kinds of materials. Supplied with a 1/2" x 6tpi bandsaw blade.
An optional floor stand is available, featuring adjustable height feet to give a comfortable working height.
  • Rack and pinion adjustment of the table tilt and cutting depth for precision setting
  • Indexable tilt lock for repeat setting at 45° and 90°
  • Machined and balanced cast iron wheels for smooth running
  • Multi V belt drive with two belt ratios give high torque and long belt life
This product is on page 30 of the Axminster Tools Catalogue View Page 30
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
