£649.98 £541.65
In stock
- get it tomorrow, Saturday 26th Sep, order within and choose Premium delivery. Delivery info
  • Sturdy and robust, fabricated from heavy gauge steel plate and cast iron
  • Can be used in any position from horizontal to vertical
  • Fitted with comprehensive guarding system
Customers Also Bought
Total: £1,317.42
The AT150BS a sturdy and robust belt sander, fabricated from heavy gauge steel plate and cast iron components. Versatile, because the belt arm can be used in any position from horizontal to vertical. The whole belt arm pivots around a very large flange with a graduated scale and the outer end of the belt drive roller is supported in its own ball bearing assembly. Fitted with a very comprehensive guarding system that allows the operator to expose only the amount of sanding belt required, but still allowing very easy changes of the belts. This machine has a large cast iron sanding table, which tilts from minus 15° to plus 45° and gives great support. When used as a linisher in the horizontal mode, the guarding can be removed to expose the maximum amount of belt and a fixed work stop is provided. The close fitting guarding coupled with two 62mm dust outlets will give exceptional extraction when attached to a suitable fine dust collector. Uses standard 150 x 1,220mm abrasive belts, supplied with a quality Hermes belt.
This machine was previously known as the BS648.
  • Supplied with a high quality Hermes 150 x 1,220mm abrasive belt
  • Large cast iron sanding table, tiltable from -15° to +45°
  • Two 62mm dust outlets will give exceptional extraction
This product is on page 58 of the Axminster Tools Catalogue 2020/21 View Page 58
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
