Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Trade AT535SS Scroll Saw
Code: 101772
  • Arm tilts 35° left and 45° right, tilting the blade, not the table,
  • 50mm cutting thickness capacity, 535mm throat capacity
  • Large 345 mm x 597 mm epoxy painted table surface
  • Now fitted with the PEGAS blade clamps for lower vibration
  • Easy access variable speed and blade tension controls
  • Organized blade storage on base
  • Onboard dust blower, under table extraction port (63mm)
  • Show More
£729.95 (£608.29 Ex. VAT)
In stock - get it tomorrow, Wednesday 27th May, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Axminster Trade AT535SS Scroll Saw
  • Pegas 36 Wood Blade Selection Pack
  • Axminster Trade AT535SS/EX-21 Scroll Saw Stand
  • Crown Thin Parting Tool
Total: £854.20
Description
In Detail
Trade Classification & 3 Year Guarantee
This 535mm(21") scroll saw is the mid sized model from a range of three with some really different features not found on any other machine. It is constructed mainly from plate steel including a 7mm heavy gauge steel table with an epoxy painted surface. Two unique features make this machine stand out from any other. Firstly, the blade actuating arms are very short, driven by a lever and rod mechanism. This gives very high control of the blade plus exceptionally low vibration. Secondly, the whole arm assembly tilts 45° from the vertical right and 35° left, leaving the table horizontal. This allows much better control of the work, due to greater visibility and being able to work at a natural position. You are not fighting gravity or bending your wrists into awkward positions. This machine is not short of other features, having a variable speed control system giving from 400-1,500 strokes per minute. Upgraded with the PEGAS "Blade Chuck" blade clamps which are much lighter, reducing vibration which reduces stress on the machine. Blade changing is easy and tool free, with two hand clamps and a quick release lever. An air blower and work hold down are provided. Plus there is efficient dust collection when connected to a suitable fine dust extractor. You are recommended to permanently mount the machine onto your workbench or to one of the dedicated stands available as an option. Using unpinned blades means there is a large selection of blades available or you can use 150mm lengths of 1/4" bandsaw blade, ideal for cutting thicker materials. Supplied with an assortment pack of Swiss made PEGAS blades. This is a serious machine for craft or joinery work, not the same as any other.
This machine was previously known as the EX-21.
Information Downloads
Promo
This product is on page 42 of the Axminster Tools & Machinery 2019/20 Catalogue.
Axminster Trade Series Scroll Saw
Benefits of the Pegas blade clamp kit
Axminster Trade Series scroll saws are fitted with blade clamp kits by Pegas.
The unique clamp kits not only improve the performance of your saw but will also enhance the finish of work.
Lightweight and compact design
Manufactured with aeronautical aluminum for resilience and optimal weight, the kits are 40% lighter than original heads.
Improves performance and finish
Reduced vibration makes the scroll saw more pleasurable to use while also improving the finish of your work.
Easy and fast blade changes
The simple clamping and tensioning system make blade changes easy and fast.
Longer life for your saw
The reduced vibration means there is less mechanical stress and extends the life of your machine.
Specification
Specification
Arm Tilt 35° - 0° - 45°
Model AT535SS
Motor Power 320 W
Nett Weight 29.5 kg
Overall L x W x H 812 mm x 380 mm x 387 mm
Rating Trade
Strokes per Minute 400 - 1,500 (var)
Stroke Length 18 mm
Table Size 345 mm x 597 mm
Throat Depth 535 mm
Voltage 230 V
Plug Fitted UK 3 pin plug
Max Depth of Cut @ 90º 51 mm
Dust Extraction Outlet 63 mm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
