£799.98 £666.65
In stock
- get it Thursday 29th Oct, order within and choose Premium delivery. Delivery info
  • Arm tilts 35° left and 45° right, tilting the blade, not the table and keeping the table level for better control and more accurate work
  • 762mm throat capacity
  • 50mm cutting thickness capacity
Customers Also Bought
Total: £815.26
Benefits of the Pegas blade clamp kit
Axminster Trade Series Scroll Saws are fitted with blade clamp kits by Pegas. The unique clamp kits not only improve the performance of your saw but will also enhance the finish of work.
Lightweight and compact design
Manufactured with aeronautical aluminum for resilience and optimal weight, the kits are 40% lighter than original heads.
Improves performance and finish
Reduced vibration makes the scroll saw more pleasurable to use while also improving the finish of your work.
Easy and fast blade changes
The simple clamping and tensioning system make blade changes easy and fast.
Longer life for your saw
The reduced vibration means there is less mechanical stress and extends the life of your machine.
This 762mm(30") scroll saw is the largest from a range of three with some really different features not found on any other machine. It is constructed mainly from plate steel including a 7mm heavy gauge steel table with an epoxy painted surface. Two unique features make this machine stand out from any other. Firstly, the blade actuating arms are very short, driven by a lever and rod mechanism. This gives very high control of the blade plus exceptionally low vibration. Secondly, the whole arm assembly tilts 45° from the vertical right and 35° left, leaving the table horizontal. This allows much better control of the work, due to greater visibility and being able to work at a natural position; you are not fighting gravity or bending your wrists into awkward positions. This machine is not short of other features, having a variable speed control system which gives from 400-1,500 strokes per minute. Upgraded with the PEGAS "Blade Chuck" blade clamps which are much lighter, reducing vibration which reduces stress on the machine. Blade changing is easy and tool free, with two hand clamps and a quick release lever. An air blower and work hold down are provided. Plus there is efficient dust collection when connected to a suitable fine dust extractor. You are recommended to permanently mount the machine onto your workbench or to one of the dedicated stands available as an optional extra. Using unpinned blades means there is a large selection of blades available, or you can use 150mm lengths of 1/4" bandsaw blade, ideal for cutting thicker materials. Supplied with an assortment pack of Swiss made, PEGAS blades. This is a serious machine for craft or joinery work and not the same as any other.
This machine was previously known as the EX-30.
  • Large 358 x 825mm table surface
  • Now fitted with the PEGAS blade clamps for lower vibration
  • Easy access speed and tension controls
  • Organised blade storage on base
  • Onboard dust blower
This product is on page 37 of the Axminster Tools Catalogue 2020/21 View Page 37
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
