£435.96 £363.30
Out of stock
- this product is no longer available online. See alternative options.
  • Precision pen and small project lathe for serious pen and project making
  • Cast iron construction for smooth, vibration free running
  • Unique pen mandrel supplied, ensures accurate, stress free turning
Customers Also Bought
Total: £486.40
This lathe has been purpose built for pen and small project turning, even on a commercial scale. It is compact and portable, but being made almost entirely from cast iron it has the weight and vibration absorbing qualities that only add to the turning experience. The main feature for pen turning is the ER20 collet chuck fitted to the spindle nose. This is an extremely accurate method of work or tool holding, the clamping being concentric every time. We have designed and included a unique pen mandrel for this lathe which creates grip onto the pen blank without exerting compression force onto the mandrel spindle, allowing it to run freely. The mandrel is held between the collet chuck and a special hollow tailstock drive centre, the bore of which closely fits the mandrel spindle allowing no play, the tailstock barrel being wound out to create grip onto the pen blank. The mandrel can hold one or two pen blanks at a time, saving time if a bulk batch needs to be produced. The lathe is powered by a 375W brush motor, being controlled by a very well made PCB and giving a spindle speed range of 400-3,600rpm. The spindle is supported within two over-sized ball bearings, running without discernible vibration. The tool rest holder is also in cast iron, with a cam lock clamp and ratchet style levers. Two tool rests are provided, 80 and 150mm. The tailstock is again in cast iron, with a smooth lead screw giving around 35mm of movement. This is a superb pen and small project lathe, quiet, smooth running and able to run all day if required. Perfect for the workshop or to take around the craft fair circuit. Accessories available as extras include a light pull drive, polishing mop arbor, 3/8" & 5/8" four prong drive centres, 1 1/2" woodscrew chuck and 2" faceplate.
Supplied with collet spanner, pen mandrel, 80 & 150mm tool rests and a centre knock-out bar.
  • Spindle nose has an ER20 collet chuck integrated for accuracy
  • Smooth, powerful brush type motor gives a wide range of spindle speeds
  • Supplied with everything you need for pen turning (except cutting tools)
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
