£1,349.78 £1,124.82
Out of stock
- dispatch estimate is within 2 weeks. Delivery info
  • Compact sized, medium duty panel saw for trade use
  • Sheet steel body and cast iron table with ground surface
  • 1,300mm sliding table and crosscut table for small panel work
Customers Also Bought
Total: £1,645.02
The AT254PS13 Panel Saw is a compact saw fitted with a 1,300mm sliding table. It is constructed largely from cast iron and heavy gauge steel, which gives strength and smooth running. The 254mm blade gives a cutting depth of up to 80mm and is amply powered by a high torque 2.2kW input 1ph induction motor. The cast iron table gives great strength and rigidity as well as providing a smooth working surface. A long rip fence, with a micro-positioning adjustment ensures straight rip cuts. There is a standard 19 x 10mm mitre fence slot in the main table. Both the blade height and tilt controls are conveniently located and lock in position. Supplied with a 1,300mm sliding table with a pivoting support leg and a crosscut table, this sliding table gives 1,250mm travel past the blade. The support table can be positioned anywhere along the side of the sliding table, also has a telescopic work support fence, a maximum of 1,850mm long, which can be fitted at either the front or rear of the crosscut table. This can easily be removed without tools for storage if required. An accurate, small workpiece mitre fence with angle scale, work clamp and edge shoe is also provided for the sliding table. Efficient dust extraction, smooth acting blade controls with position locks and an easily adjustable rip fence contribute to ease of use. Included as standard are a 254mm Axcaliber TCT fine cut main blade, a rear feed-off table and table support legs. This saw is a great all rounder for a small trade workshop and would equally suit a home based woodworker looking for a saw for bigger projects. N.B. 16A 230V Supply Required, plug fitted.
  • Sheet steel side support and rear feed off tables included
  • 254mm diameter TCT blade gives up to 75mm depth of cut
  • 2.2kW 1ph induction motor, requires 16A supply, plug fitted
This product is on page 13 of the Axminster Tools Catalogue 2020/21 View Page 13
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
