PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
This kit is designed to upgrade the crown guard facility on older circular saws that commonly have either a simple ineffective set-up or even no crown guard at all! It is easy to adjust to fit almost any medium-sized circular saw, including those fitted with a side support table. With a set of height adjustable feet, telescopic arm and lower support, there is plenty of adjustment. The clear Perspex hood is wide enough to allow for blade tilt and has a parallel system to keep the hood lowered over the blade. The kit also provides for extraction from above the blade, leading to a 100mm port at the end of the arm. A simple bracket enables the kit to be bolted to the saw; just two holes need to be drilled into the machine's casing. The top arm can also be swivelled away from the blade to allow blade changing. To check whether this kit would suit your saw, the top arm reach is 1,000-1,700mm. Lower support arm adjusts from 1,080-1,280mm. Suits table heights from 900-1,050mm. Suggested max blade size, 305mm with a scoring blade, 355mm without.
Crown guard and extraction kit to suit many circular saws
Suits many older machine where either a poor or no guard facility is fitted
Has a wide range of adjustments to suit many machines
Crown guard is wide enough to accommodate a tilted blade
